FixYa.com
Tags:
Sewing Machines
Generic problem for all Sewing Machines
Machine Embroidery - Bobin bunching up underneath
posted by WendyWooWoo on May 18, 2008
I have beem merrily embroidering away on my Bernina Deco 340 but following a thread change the bobin now bunches up after only a few stitches. This is a design I have sticthed out previously on material and with threads I have combined on many occassions.
I have tried changing the bobin, changing the thread, changing the needle, adjusting the tension, adding more stabilising materials, turning the machine off for a few hours and have now run out of ideas! I have also taken the bobin out and dusted in there but no joy!
Can anyone help please?
Many thanks
Wendy
Comment by WendyWooWoo, posted on May 18, 2008
Thanks, doesn't sound silly at all - in fact I am probably missing something silly and just need someone to point out the obvious! However, I did have the presser foot up and have checked the thread is going through easily. I have unthreaded and rethreaded many times, even changed the colour thread (just in case the machine somehow knows!!!)
Wendy
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
allmakes
Rank:Wiz Wiz
Rating: 84%, 1041 votes
Hello Wendy,
This may sound silly but did you make sure you had the presser foot up when you threaded the machine and did you make sure you adjsuted the top tension when you changed the thread?
Rating Locked! (?) WendyWooWoo has rated this solution as Thanks for Trying
This Problem Also Relates To: Kenmore 15212 Mechanical Sewing Machine Kenmore 19365 Computerized Sewing Machine Kenmore 19606 Computerized Sewing Machine Kenmore 12102 Kenmore 756A-30BH Mechanical Sewing Machine Brother XL-2600 Brother XL-5340 Mechanical Sewing Machine
Can you Help with these Sewing Machines problems?
Sewing Machines
Fabric won't advance, bobbin...
I broke a needle while sewing... Answer This...
Singer 3116 - SIMPLE
I have an old circa
I have an old circa 1975 Singer... Answer This...
Singer 7462 Mechanical Sewing Machine
button holes
I made one button hole then... Answer This...
Brother LS-2125 Mechanical Sewing Machine
I cannot get the needle to...
When I lower the needle in to... Answer This...
Sewing Machines
Button hole problem
I can't seem to get the machine... Answer This...
Repair Service
Find Sewing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
