Question about ASUS SiS Chipset P4S133 (P4S133/PA/LAN) Motherboard
Pc does not boot
Hi dears
i replace mainboard battry with a new one and when i reboot, the pc does not boot . i remove all Ram ,H.D.D, graghic cart ,.. and still pc dos not boot
any help please?
  • asghar_kopak May 18, 2008
    hi
    but pc does not boot at all and screen shows nothing to check if first boot is hdd 0 or not
    please help
Is there any power that is coming from your power supply? does the green LED on the motherboard lighting when you turn on your avr?
Posted on Oct 25, 2008
Hi i think you need to check your bios cus when your take out the battery the bios resets see if the first boot is set on your hard drive on my pc it is set on hdd 0
Posted on May 18, 2008
  • ASUS Master
  • 13,433 Answers
Put in one ram, video card. Try again
also buy a 4digit post card to find out what the problem actually is.
heres a similiar 2 digit card have a look
http://www.darkwire.com.au/html/standard_isa___pci_post_card.html
On ebay you can get a 4digit card for less than 20 usd.
  • 86 Answers
Check the battery compact with your motherboard ,You have to fix the Ram and check it.
ASUS XP PROFESSIONAL MODEL K8V-VM
Hello try to insert the old ram module again.
Your mainboard uses DDR ram, not DDR2 or DDR3 these to will not fit the socket.
The mainboard only supports up to 2 gb of ram.
If more ram is insertet, the mainboard will not boot.
More info can be found here at ASUS:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=20&m=K8V-VM&os=17&hashedid=IQoVElAYUAC4aAz3
Try to download the manual, by selecting your windows system.
You will need adobe reader, to read the content.
The manual should also be helpfull when connecting the cables in the right order again.
Remove also any dust inside the pc, with compressed air.
And take antistatic precautions when working on the mainboard !!
Hope you will get the pc running again :-)
Jun 20, 2013 | Computers & Internet
My laptop is not booting. its showing enter passward in blue screen.
somebody set the bios password to reset the bios password open the back cover of ram u see a small battry like a coin remove it fo10 to 20 second and remove laptop battry at same time then plug the adapter u will see baios was reset if u have any qury plz tell me the laptop model no and manufacturer
Sep 15, 2011 | Computers & Internet
Got an AsRock P4i65G mobo and bought 2 gig RAM for it. However, I have bought ECC memory by mistake instead of Non-ECC. PC wont boot with the new RAM. Is there any way I can get this to work such as with...
Hi, you can download a manual here:
http://www.asrock.com/mb/overview.asp?model=p4i65g
Your mainboard DOES NOT SUPPORT ECC RAM.
This ram type is ONLY intended for servers
or mainboards that are compatible for that ram type.
This is what your mainboard supports:
Dual Channel DDR memory technology
- 2 x DDR DIMM slots
- Supports DDR400/333/266 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
Use only the asrock site when upgrading the bios.
And a bios upgrade does not supports the ecc ram anyway.
Hope this will help you.
Aug 20, 2011 | Asrock P4i65G Motherboard
HP media center pc ,1170n will not boot. black screen. You can hear the fan come on but black screen.
Sounds like a capacitor has blown on the motherboard, but before condemning it, check the following:
1.) Does the CPU fan turn and does the heatsink get warm after a few minutes?
(This indicates that power is at least getting to the CPU
2.) Check connections of ALL the main power connectors (ie: the 20/24 pin plug to the mainboard and the smaller 4 pin plug to the mainboard.
(If not firmly inserted will stop the board from firing up)
3.) Check the graphics card is firmly seated and test with anew graphics card to eliminate the issue being with the graphics card / check tightness of the VGA cable to monitor and card
4.) Remove all but the main power and 4 pin power plugs and try rebooting to eliminate hard drive or DVD drive failure
5.) Remove and replace each ram module in turn try booting in between
6.) If you have a spare PSU, replace the existing one and test the board using that, sometimes the PSU appears to work, but lacks power to fire up the board.
After all that, you are down to the mobo or CPU, you can try a new CPU, but I feel that the issue is with a blown capacitor or a burned circuit trace, only close inspection of the mobo will reveal bulging, leaking or blown capacitiors (small cylinder like things on the motherboard)
Jan 17, 2011 | Computers & Internet
Hello, my Compaq SR2010NX has had a nissue in rebooting with no video output for a few weeks now, getting worse as time goes by, repeat boot and turning on monitor at specific timestamps in boot up helps...
Hi friend,
Your system RAM is faulty,please replace the RAM with another RAM or if you are using 512/512 MB two RAM,remove the RAM vise a versa(one by one) and check.
Thanks,
Jan 28, 2010 | HP Compaq Presario SR2010NX PC Desktop
Won't boot up gets blue screen asking for us to
Usually if you've encounter a blue screen the first cause of this should be the RAM. Check the RAM maybe it is clogged by the dust you need to clean the RAM. If the same things happen you must reset also the CMOS battery and the jamper. The jamper located near the CMOS battery at the south bridge.
In any other circumstances to solve this you need to install a fresh copy of windows. Some causes of blue screen is the corrupted software that need a full copy.
Dec 02, 2009 | Dell Inspiron B130 Notebook
My PC no longer reboots. If I turn it on the fan spins and DVD rom also ejects but it doesn't reboot. It used to have an error when I reboot my PC "Chasis Intruded" but I still manage to turn it on. After...
dear it once happen with my pc too but i open my whole pc and clean the dust from the main board,ram....
then it start working i think it is due too dust particles that sometimes short the mainboard
try this and tell me
Nov 05, 2009 | Computers & Internet
Intermittently After Startup the PC Reboots Automatically
Did you do something that come up to that problem? Or does the problem just occur?
Oct 24, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
How win xp boot faster
Dear
If u dont wanna to exceed ur RAM...
1. click start-run than type "msconfig"
2. go to startup tab uncheck all than ok
3. Pc will reboot now
4. uninstall  unuseable  programm
its working
Oct 18, 2008 | Computers & Internet
Medion pc keeps rebooting just as starting to load win xp home
Sir your useing windows xp os ok your Probalm finaly turns off & reboot some .dll fils are missing so your install new software for your pc ok by .
Mar 15, 2008 | Medion MD-1704 PC Desktop
ASUS SiS Chipset P4S133 (P4S133/PA/LAN) Motherboard Logo
93 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
