Question about Sony Playstation 3 (PS3) Console
Playstation 3 My ps3 turns on but I do not get any output via the AVI connection. The unit hasn't been used for about 2 months due to a move. I do not have any HDMI connections on the TV
  • Sony Master
  • 13,433 Answers
Is this a new tv? are you useing the hd connector on the playstation?
Your tv might not be hd ready what is the brand and model of your tv?
Posted on May 18, 2008
Hi, My ps3 used to play avi files and now whichever one i use it ownt play( eve if it played it previously) its pauses and a small clock appears in the bottom left hand side of the screen. I dont...
1) Reset the settings on the PlayStation 3 by having the unit turned off, then pressing and holding the power button on the front of the unit until you hear it beep twice (shouldn't take more than 7-10 seconds), then release. All of your settings will be reset to the factory defaults, and you can make adjustments as needed.
2) if you are streaming the avi files from a media center via wifi it is more than likely a connection error try hooking up your ps3 directly with an ethernet cable to your router if possible this should fix the problem
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
I have a television and when I connect the playstation I ca not see anything on the screen but if I use another television it works fine what could this be
This is because your output video is set wrong for your television. Please follow these steps to try and fix the problem.
Step 1. Turn the PS3 into standby mode (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear the second beep.
Step 3. Wait for the PS3 to boot up.
This basically resets the video output back to standard definition and you should now be able to configure your video settings properly via the system settings.
Hope this helps and thank you for using Fixya
Aug 12, 2010 | Sony Playstation 3 (PS3) Console
My ps3 will not output anything over 480p. I have used it at 720p for 8 months now. When I loaded Modern Warfare 2 it blipped and the tv said Mode Not Supported. It cycles through all the tv options and...
May be worth a try
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 27, 2010 | Sony Playstation 3 (PS3) Console
Nothing shows on screen when inserting game , i hear the disc is turning but nothing shows on screen
Make sure you have the cables hooked up properly, regardless of whether your using an HDMI cable or regular A/V cables.
Best thing to do in a case like this is to do a factory reset on your PS3. Be sure that the A/V cables are being used originally and are hooked up properly.
Here is how to do the factory reset on a PS3:
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Try that, if you still don't get video and you know the cables and the TV are set to the right output then its an issue with the main board not having any output.
Apr 22, 2010 | Sony Playstation 3 (PS3) Console
I am having a problem getting my ps3 to display with an hdmi cable, this is the same one i have been using for a year, it has no problem with the avi outputs but when i try to switch the output to hdmi......
Please try the following :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Oct 19, 2009 | Sony Playstation 3 (PS3) Console
While on vacation switched to 1080 now home and have regular tv now cant see to get back to regular. Im to the far right of menue. Need to know many to go right, down, button to hit to enter and then how...
Try resetting the video output. Follow the steps below:
  1. Before changing cables, make sure the PLAYSTATION 3 is turned off using the main power switch on the back of the PLAYSTATION 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PLAYSTATION 3 and television (or display) from the wall socket.
  3. Make sure the AVI cable is connected to the [AVI OUT] port on the back of the PLAYSTATION 3 system.
  4. Connect the other end of the AVI cable into the [AVI Input] port of the TV or display monitor.
  5. Plug the PLAYSTATION 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PLAYSTATION 3 back on (the line on the power button is now pressed).
  7. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Thank you for using fixya!
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
Sound but no picture
Hook up the composite cables that come with the unit. Turn the TV on to the correct input. Turn the PS3 on using the power button on the unit. When you press the button continue holding the button until you hear a second beep....about five seconds. That should set the PS3 back to the factory output. If that corrects the problem you can set the PS3 to use whichever cable you want via the XMB.
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
Cannot connect ps3 to lcd tv via hdmi cable
First off make sure ALL Units using HDMI are Powered OFF! Connect Cable, Then turn on all components. On the PS3 Crossbar (Menu) go to the 2nd column on the left, Then down to Display Settings. Choose Output Settings, Choose HDMI, Use AUTOMATIC. Then do the same with the Audio, HDMI, AUTO Make sure your TV is on the Right HDMI Input! Good Luck!
Apr 25, 2009 | Sony PlayStation® 3 (80GB) Console
Playstation 3 Audio setup
have you played a game already?
the PS3 system is known to lag the optical while on the X-cross media bar (menu).
Aug 07, 2008 | Sony Playstation 3 (PS3) Console
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
64 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
