Question about Hotpoint FFA70 Bottom Freezer Refrigerator
Ffa70 hotpoint fridge freezer
Food defrost light has bn on for two days and fridge has been freezing food even when turned down, freezer is on fast freeze,cant seem to get it to temp,fridge freezer is second hand but only 3 yrs old!
  • 828 Answers
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
Hotpoint AAf70 how do I turn the auto defrost off
There is no way to do this, the machine requires the defrost timer to function. I don't really understand what the problem your having is.
Jun 06, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70
This will work in most all cases of this type. You need a piece of copper wire, 14 guage, 12 to 16 inches. You can shortin it as you need to Turnoff the power to the fridge. Rap one end of the wire around the evaprorator heater and feed the othe end down the drain tube. This wire will heat up when the heater comes on and will supply heat down into the drain tube hopefully preventing the drain from freezing.
Nov 19, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint ffA71
ffa71 fridge and freezer warm and food defrosted. red light is on. Back of freezer making normal noise. Help.
Aug 27, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
FFA70
these machines commonly do not defrost sometimes an intermittant fault
remove back panel from freezer and if im right, the pipework will be iced up especially at the top. de-ice carefully with a hairdryer but don't blow hot air on the stats mounted on the pipework. turn on and check fan runs as well
Jun 29, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
HOTPOINT FFA70 FRIDGE FREEZER
I had this problem and it was fixed relatively easily. Get everything out of your fridge freezer and switch it off overnight to allow it to defrost.
In the bottom freezer compartment there is a panel behind the draws which you can remove but you will need a special tool from a DIY shop. Its like an allen key, but with a star shaped end.
When I got the panel off I found that the filament was covered thick with ice even though it had been off for hours. No wonder it wasn't working properly. I melted this with a hairdryer. You want to take your time with this as you could easily damage the freezer if you try chipping the ice out.
Freezer works perfectly now and is very quiet.
Jun 02, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
955 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
