Hdd shows on bios as a slave but not in explorer
  • 13,433 Answers
Have you partitioned and formatted the harddrive?
Posted on May 18, 2008
Today I installed SATA HDD at red SATA port 1 . But in BIOS, it shows Primary IDE master not detected....Primary IDE slave not detected....Third IDE master detected..I wanna know why my HDD is not detected...
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Jun 12, 2011 | ASUS P5GC-MX/1333 Motherboard
Hi I've Vaio VPCSC1AFM with Win 7, boot is impossible -"Operating System Not Found", HDD is also not visible in BIOS. I can hear that HDD is working.
* Look in your BIOS, I've it can detect the HDD.
( Press the F1 or F10 key after restarting the computer) * Make sure all the cables are connectedproperly.
* It might be a jumper setting.
I've you have 2 HDD's on 1 cable, you need to have 1 Master & 1 Slave,or else your HDD(s) wont show up & other problems.
Jumper settings below (Yourjumper settings might be different !)
I've this all didnt work, either your HDD or your MOBO is broken.
Jun 03, 2011 | Computers & Internet
Computer powers on and runs but it will not post hhd in BIOS. any help?
Shut down you're system. Open you're case and double check the power cable and data cable from hdd to motherboard. (Disconnect both cables and re-connect both). Make sure the cables are fully inserted. Power up the system and enter the bios. The hdd drive should be listed. If not replace the data cable with a new one and check the bios again.
If you have two hdd, ATA IDE drives connected, make sure that each hdd is jumpered correctly. One set to Master with a slave.
The second drive should be jumpered as a slave.
If you're running 1 hdd make sure the hdd is jumper as a Master without a slave. There is a sticker on the hdd to help you set the jumper correctly.
If the bios still does not see you're hdd than either the hdd is bad or the motherboard controller is bad.
To check if the hdd is faulty, check the sticker on the drive. Find the manufacture's name and model. Google the manufacture's name. Every manufacture provides free software that will test and repair the drive by allowing you to create either a bootable floppy disk or bootable CD disk that runs in a DOS like window. Example: For a Seagate drive you would download SeaTools for DOS. Instructions are listed on the site;
Seagate also supports Maxtor drives using the same software.
Apr 08, 2010 | HP (D7580-60003) Motherboard
How to set master, slave settings in sata hdd
In first HDD put the jumper in first vertical pair of pins from power socket side, it will become master and second HDD put jumper in second vertical pair of pins from power socket side it will become slave.
Feb 02, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Msi k8mm-v board not detecting SATA 320 GB HDD
peets, is this drive a slave drive? if so, make sure you have the jumper ******** the hdd set for "slave" , the instructions that came with it and on top of the hdd itself shows you where that is. You should have it set up for this anyways so you can format it to your liking(i.e. if your going to partition it out or use the whole 320GB for your data). after doing this you will need to go to you bios screen when you boot up your computer(setup). Go to standard or advanced bios settings and see if the new hdd is there, your bios should recognize it, if not, make sure you write down all the info for your hdd (size, cylinders, heads, type) and input the info for a correct installation and when you are finished, make sure you save the info (F10) and (Y) computer will restart and it should see the new hdd. Also, I take it you have CD/DVD driveconnected to your primary SATA or IDE port, this should not be a problem, if so send a msg back.
Dec 14, 2009 | MSI K8MM-V Motherboard
My second hard drive (slave) sometimes works and
try to find out if all cables are properly attached, that in bios both IDE channels are set active and ide(hard/drive detection) is set to auto.
Exit saving changes. reboot and wait if in boot-up screen hdd is shown. Now you have made sure the hdd is being recognized from the hardware side.
Boot up windows and check if it is listed in the explorer.
IF yes, youre lucky.
if not, run hardware detecton and wait for results.
IS it now?
if yes goto properties, tools and check disk thoroughly.
back-up data, format it(long version!). check again.
(Now any invalid or broken clusters are marked)
Hope this solved the issue!
Aug 04, 2009 | Gateway Computers & Internet
No icon showing in My Computer for slave HDD
On XP computer install your seagate barracuda 400g. start the computer. when xp is already boot right click My Computer then select manage. When Computer Management dialog box appear click disk management. Look for the drive that is unallocated and format the drive and follow the instructions.
Feb 17, 2009 | Acer Computers & Internet
FAT to NTFS without Format
Use the following link to repair the windows file system if you have the windows xp cd
Dec 26, 2008 | Seagate (9Y7275557) 400 GB Hard Drive
ASUS P4S533 mother board not supporting full 160 gb
This is happing becuase of your motherboards BIOS !
Really, this happened to me too. You see, our motherboards which are very old cant support above 80 and so on. This is beacuse of the BIOS. You will need to update your BIOS inorder to give new features.
Try go to the Asus home page and download the latest driver for your motherboard. Then install it in your motherboard's BIOS. There is intructions for this in the Asus's home page.
Mar 08, 2008 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
