Question about Canon PIXMA MP160 All-In-One InkJet Printer
CANON PIXMA MP160 E3 error
Hi all! My trouble is the following: when I try to print or to make a copy, the paper goes through blank, then the next leaf, and then E3 appears. What do I have to do? Probably there is a problem with cartridge, or?
  • 8 more comments
  • Jim
    Jim May 24, 2008
    CANON MP160 E3 error code problem.
    My printer attempts to feed the paper, then it stops, E3 error code appears, I press green <|> switch to feed through the suposedly jammed paper, the paper feeds through the printer. (no paper jam to block it)
    I try again to print, the same thing occurs. (still no jam)
    OK CANON, about time you lot got off your backsides and addressed this problem, you are getting a BAD product name with this range of printers.
    How about some FIXes before you lot got no customers left.
    I pulled my printer apart (because it is mine now, not yours) twice to look for the jammed paper, THERE IS NO PAPER JAMM. do you hear us all THERE is something else wrong. OK..
    By the way your printer ink C O S T S T O O O M U C H T O B U Y
    It is a rippp offf, 1 litre of petrol costs $1.34, your Black ink costs $21.00 for 2x 20ml plastic refills, you lot are just GREEEEEEADY
    Now if its not too much trouble, I would like a repair fix.
    Have a nice day
    Jim D
  • Anonymous Jul 04, 2008
    I am having the same problem with my printer as Jim D
  • Anonymous Aug 07, 2008
    everytime i turn on the printer it says 3e i print something and it says its jammed, remove the paper and it ays remove the papaper but it has not printed
  • jed_ky03 Sep 22, 2008
    i looked at the 2 white wheels and they r both moving,dont look broken. i got this printer free with my computer, but i guess im just going to go get one of the 30 dollar walmart specials until canon gets their head out of their *** and fix's it..............
  • lmedders925 Sep 24, 2008
    i have the printer same problem paper goes threw nothing prints the paper. and e5 wont goes away
  • ilduo Oct 27, 2008
    Any hints on removing the back of a Canon MP160 printer/copier in order to access the paper feed rollers?
  • Anonymous Jan 10, 2009
    NO MEU CASO, A MINHA IMPRESSORA MP160 TRAVOU TODAS AS FUNçõES E DAVA A MENSAGEM "E3" PISCANDO.
    ESSE ERRO SE DEU DEVIDO A ELA TER PUXADO MAIS DE 50 FOLHAS DE UMA Só VEZ, A SOLUçãO FOI DESMONTAR A IMPRESSORA E COLOCAR NO LUGAR A PEçA RESPONçAVEL POR PUCHAR AS FOLHAS. ESSA PESSA é A MAIOR DAS 2 RODAS DE BORRACHA QUE PODEMOS VER QUANDO OLHAMOS NO LUGAR ONDE COLOCAMOS AS FOLHAS. OBS: é BEM FACIL DESMONTAR A IMPRESSORA.
  • sojnol May 11, 2010
  • HELPY101 May 11, 2010
    WHAT DOES 2E MEAN? THIS PRINTER IS DRIVING ME NUTS PLEASE HELP
    MY PRINTER SAYS ALARM AND E5 AND YET THERE IS NO PAPER JAM OR ANYTHING IN FACT IM ACTUALLY TRYING TO SCAN AND STILL DOESN'T WORK!!!!!! HELP!!!!!!
I work in a shop repairing these printers and have had a large number with the same fault - displaying E-3 with no jam in the paper path. This is caused by a broken part in the paper feed mechanism that pevents the printer from taking the paper. The part located right at the bottom of the printer looks like two white gears connected together with a central spring. At present I am trying to find a supplier of the spare parts - will check back.
Posted on May 28, 2008
I solved this error by powering it off, picking it up, and shaking it violently. There was clearly no visible piece of paper jamming it so whether it was dust or just the sensor acting up, it is now fixed
Posted on Sep 05, 2010
  • Grasscycler
    Grasscycler Oct 03, 2011
    I did the same after spending hours of troubleshooting trying to fix an E-3 error when I could clearly see there was no paper jam. Kinda silly having to admit it, but it simply needed a good throttling I guess. I was just about to take a bat to the thing when I read this post. Thanks.
    - Grasscycler
  • 59 Answers
I found out what is E 3 error on my pixma mp160.it was the paper feeding mechanism.i fixed it but after 2 parers loaded jammed again.it's a plastic mechanism and fragile.where the waste ink goes, there u will find 2 gears jumped out, sticked togheter whit a 33333333 arch.if u put them back in place the printer will work .
Posted on Aug 26, 2008
    Problem Solver:
  • 25 Answers
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
a3
Posted on May 21, 2009
    New Friend:
I've solved giving some hits to the printer against a surface, without much force. Regards.
Posted on Jan 01, 2013
I got the same error E3 paper jam, with no visible jam. I used a Compressed Gas Duster to it and sprayed everywhere I could in that darn printer...then pushed through 3 papers (to clean it), then it started working again!
Posted on Apr 08, 2011
    Problem Solver:
  • 7 Answers
E3 ,paper jamed. 1st chek the roller or something object in the printer 2sd triming **** filem sensor,last chek the purge unit maybe damage.
Posted on Jun 20, 2010
  • 24 Answers
Hi, look at this post maybe can solved your problem not all Error E3 means your printer part damage but maybe somethings inside it that makes the printer look likes paper jam, read it at http://slayo.com/how-to-fix-error-e3-canon-mp198-printer.html Enjoy
Posted on Jun 01, 2010
This is the page unit!!!!! i ve got the same problem! does anyone know where i can find a part?
Posted on Jul 05, 2008
I am sorry to say that, the part you are specifying hereis not broken in the paper feeder mechanism of the machine, I have check it very sharply. Please check for other solution for this problem.
Posted on Jul 09, 2008
My cannon MP160 pixma keeps telling me there is a paper jam when there is no paper in it, it will copy and give me color tests printed out but if i try to print a doc. It says E# paper jam
Hello thanks for using fixya
Actually you are facing E3 error, E3 error is mostly because of paper jam. their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon service provider.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Feb 07, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer will not feed paper and displays error code E3... have tried cleaning the feed mechanism as per the owners manual but problem persists
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
tokl-20
Aug 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
MP 160 flashing error E then 3. doesn;t respond to anything I try to reset it
hi,
mbhd13
Jun 19, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Describe your Canon PIXMA MP160 All-i have a
hi,
pow-e-r-18
Jun 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error E3 on Pixma MP160
Looks like there is something stuck in the insides of the printer preventing it from running to one side. A small paper clip, Ball pin etc., can cause this. You might have to take it apart and look for it. I had fixed a similar problem recently and the stuck object is "HAIR BALL!"
Jun 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Mp160,error code e3
hi,
587
May 19, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Pixma mp160 error message
Ok, my machine was also showing E3, and would NOT go away. My solution: turn the machine off, feed a piece of thick cardstock into the paper feed.Turn the machine on, let the machine take the paper almost all the way in, then pull it back all the way out against the feed. My E3 disappeared and has not yet returned!! Hope this helps David
Nov 26, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Not print or copy
posible a small piece of paper jam in the senzor. check please the entire paper path
Oct 17, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
16,087 people viewed this question
old marine
old marine
