Question about Toyota SE-06 Mechanical Sewing Machine
Toyota 5000 Sewing Machine
I have an old Toyota electric sewing machine which has always been very reliable. The place I bought it from has closed down some years ago. It has suddenly stopped feeding the material, either backwards or forwards. We took the top off and oiled various bits with little effect. Changing the stitch side does not make any difference.
Can you help please?
Sandra
  • Sandy45 May 18, 2008
    Thanks for trying but yes I have had the machine for a number of years and the teeth are just above the plate, but maybe not as high up as they used to be but I cannot see how I can raise them up.
    Sandra
RickE1
  • 202 Answers
SOURCE: backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Posted on Jan 11, 2009
  • 9 Answers
SOURCE: lost instruction manual for toyota 2400 sewing machine
just visit us at www.janomestuff.com to avail for a new manual
Posted on Sep 18, 2009
Zenqi
  • 208 Answers
SOURCE: started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Posted on Nov 14, 2009
SOURCE: I have a toyota js021
I had the same problem the nylon gear on the main shaft was worn and would not make contact with the shuttle shalt gear
Posted on Feb 25, 2011
wentlanv
  • 710 Answers
SOURCE: I have a Toyota 2700
Can you get inside to get at the lever? Spray the reverse mechanism with sewing machine oil or WD40. Be sure to clean the mechanism first.
If the feed direction is forward after you oil it, great! If not, it's off to the repair shop.
I hope this works for you. Thanks for visiting fixya.com
Handie Andie
I'd appreciate your vote. Thanks.
Posted on Apr 12, 2011
Looking to download manual for reliable msk-588
RELIABLE MSK-588 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > ... > Reliable Manuals > Sewing Machine > MSK-588
View and Download Reliable MSK-588 instruction manual online. Portable Blindstitch Machine. MSK-588 Sewing Machine pdf manual download.
Reliable MSK-588 Manuals
https://www.manualslib.com > Brands > Reliable Manuals > Sewing Machine Reliable MSK-588 Pdf User Manuals. View online or download Reliable MSK-588 Instruction Manual, Specification Sheet.
RELIABLE MSK-588 SPECIFICATION SHEET Pdf Download.
https://www.manualslib.com > ... > Reliable Manuals > Sewing Machine > MSK-588 View and Download Reliable MSK-588 specification sheet online. Reliable Corporation Professional Portable Blindstitch Specification Sheet. MSK-588 Sewing Machine pdf manual download.
Jan 15, 2018 | Reliable Sewing Machines
Homestyles sewing machine F08 702 H 01: Are they ALL caca, or just mine?
If it was purchased second-hand, very likely something is wrong with the machine or the owner didn't know how to use it. It is always best to test and have the owner show you how to use the machine before purchasing. From the information found online, this is a very economical level sewing machine--even new.
JMHO, but purchasing an old mechanical machine from a sewing machine shop for $60 would probably yield a more reliable machine. For most sewing, a straight stitch and zig-zag are the most frequently used stitches. So, if you are unable to purchase an upper-scale machine with multiple built-in design stitches for several hundred dollars, stick with a simple mechanical.
Jan 01, 2017 | Sewing Machines
I have a brand new reliable industrial sewing machine msk-8400bl18. i had a sewing machine guy out that showed us how to use machine, thread etc. about a month ago. everything went smooth and sewing...
hi.
given that the machine is only a month or so old, the best advice i can give you is to do nothing to the machine and call the sewing machine guy out to repair it for you. a brand new machine like this will be covered by the warranty. as long as you have actually switched the machine on properly, any faults are the responsibility of the supplier at this stage.
Jul 26, 2011 | Reliable MSK8400BL25 Mechanical Sewing...
Frozen machine
Hi this is techcrazy
the motors in ur sewing machine is not runnin because there is no proper rotational motion inside the motor of sewing machine.so one way of rectifyin is replacing the old pair of magnets with new ones..which may prove costly.so if possible my sincere advise is to go in for a new one
please do rate me on this solution
Feb 02, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Need manual
There are a couple of places that are selling scan pdf version of the manual. Couldn't find a free one. The Toyota Sewing website didn't have any support download pages => http://www.sewtoyota.com/
http://sewingwishlist.com/toyota.html
http://gotoes.org/sales/ToyotaSewingMachineManuals/ViewInfo.pl?Toyota=1&Sewing_Machine_Model=4500-EL
Dec 26, 2008 | Toyota STF39 Mechanical Sewing Machine
I need to know where i can find a bobbin for a janome sewing machine in the philadelphia area
After I bought my machine years ago, I bought a whole bunch of bobbins on Ebay! Cheap, too. And I have never come close to using all of them. That's a great place to start. Good luck.
Dec 17, 2008 | Janome Memory Craft 9000 Computerized...
Toyota SE-06 Mechanical Sewing Machine Logo
276 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
