Question about HP Color LaserJet 2600n Printer
I have change the ink cartridge but it is still printing not very clear it is very ffaded
  • lnc1969 May 18, 2008
    In printing a shed in paper.
  • Anonymous May 20, 2008
    The tone is paler on the left hand side of the page when printing in colour. I am told that the develper unit needs changing, but I'm not sure. If it does, how do I do that?
In printing a black shed all the paper
Posted on May 18, 2008
How to change cartridge after ink has dried
Changing the ink cartridge is not the only problem, the print head will need to be changed as well.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 20, 2011 | HP DeskJet 3745 Printer
Will not print in black. will print in color. I
Sounds like a badly clogged nozzle. If you are using aftermarket/refilled cartridges, the changes are the ink is not up to manufacturer specs and has dried and clogged the nozzle. The best way to clear this is to take a new black ink OEM cartridge and run the deep cleaning a number of times (at least 3) to see if the nozzle can be cleared. If you continue to use non-OEM cartridges, I would keep a set of OEM cartridges around for nozzle clearing purposes. Also, take the aftermarket ink cartridges back to the vendor and either get an upgraded cartridge or refund.
Let me know if this corrects the problem. Thanks.
Mar 18, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Printing with no ink
1. Lift the front cover, and wait for the printer to move the old cartridges forward.
2. Take off or pull the clear plastic tape off of the back of the cartridge.
3. Pop the cartridge holder off of the top of the cartridge you are changing and pull the old cartridge out.
4. Carefully insert the new cartridge into the holder until it snap in place.
5. Close the front cover.
6. Your printer will automatically recognize the new cartridge.
7. Try to print a test page.
Oct 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have just changed my black ink cartridge however still patchy
Typically you do not have to change the color cartridge when you replace the black cartridge.
As far as the spotty printing, it sounds like you have some clogged nozzles caused by the lower quality of ink in refilled or aftermarket cartridges. There cartridge inks may not be up to specification. This is especially true for the ultra fine printers.
To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity at least twice followed by the alignment utility. This should clear up the problem with the spotty and washed out printout.
Let me know if this solves your problem otherwise we can explore other solutiions. For the record, which printer do you have?
Please rate this solution. Thanks.
Oct 07, 2009 | Office Equipment & Supplies
Text is not printing clearly.
Change the photoorganic drum and the cleaning blade,if the cartridge is refill 2 or more time change the cartridge.
Sep 07, 2009 | Office Equipment & Supplies
Brother mfc 5840 won't print clearly
you need to check the maintainence kit and see if it's full. Also if it isn't, use some iso-proponal alcohol and some q-tips to clean the print section of the cartridge and the cartridge tray.
Aug 21, 2009 | Brother MFC-5840CN All-In-One InkJet...
Dell A920 cartridge stall error.
Hi, I HAD the same problem, but not anymore!! I just opened the top to expose the "inside of the printeri" and checked the long clear band at the rear behind the print head. Make sure that the clear ribbon is NOT TWISTED. There is a small metal bar with a small extended part on the far left interior of the printer. Just make sure that the slot on the clear band is fitted on that extended part. This will put the print head back "on track" This worked for me!!
May 30, 2009 | Dell A920 InkJet Printer
Kodak esp-3 cannot purge air from print head
Apr 23, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Mp140 e2
E3 – Paper jam error.
How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
E4 – Empty ink tank.
How to correct, fix: An ink cartridge is empty. To cancel printing, press the <Stop/Reset> button. To continue printing, press <Black> or <Color> button. After printing completes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause the machine to malfunction.
E5 – The ink cartridge(s) is not installed. The ink cartridge(s) cannot be recognized.
How to correct, fix: Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. If one of the ink cartridges is missing, this error can occur.
E7 – The ink cartridge is not installed in the appropriate position.
How to correct, fix: The ink cartridge is not installed in the proper position. Install each ink cartridge in the proper position.
E8 – The ink wasteabsorber is almost full.
How to correct, fix: The waste ink absorber is getting full. Press the <Black> or <Color> button to clear the error and continue printing. Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service. The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
E9 – A specified period of time has elapsed without receiving a response from the digital camera. A print mode compliant with PictBridge is not selected. A specified period of time has elapsed without receiving a response from the digital camera.
How to correct, fix: The machine cannot communicate with the connected camera. Disconnect the cable between the machine and the camera to clear the error. Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct. If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge. Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time. Re-connect the cable between the camera and the machine.
E14 – Ink cartridge cannot be recognized.
How to correct, fix: Unsupported ink cartridge may be installed.
E15 – Install only recommended ink cartridges.
How to correct, fix: Install only recommended ink cartridges.
E16 – The ink level cannot be correctly recognized or detected.
How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
E19 – Scanning failed error.
How to correct, fix: Scanning a document failed. Check if the document is placed in the correct orientation position and try the operation again.
Aug 01, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon bjc-85 printer doesn't print anymore
Have you tried changing the green carrier? That solved my problems with no ink.
Dec 04, 2007 | Canon BJC 85 InkJet Printer
HP Color LaserJet 2600n Printer Logo
156 people viewed this question
Ben Johnson
