Question about LG KG800 Cellular Phone
Lg chocolate where is the ariel bit inside the lg chocolate? mine is working fine after putting a replacement housing on it, fine apart from it wont find my network haha! am stuck now!
Hello!
whrn i slide up my kg800 it turn white can u help me
Posted on Jun 07, 2008
Lg chocolate touch screen not working
I have a LG Chocolate BL 40. It fell down and cracked its display screen from several loactions. So I got a the cracked display screen replaced with a new one. All seems to be working fine except that when the call comes the answer button which used to display as green gets greyed out and does not lets you answer the call. I have tried upgrading the software as well as a factory reset bit it has not helped. C
Can somebody advise how/if it can be fixed?
Aug 28, 2010 | LG Chocolate 3 Cell Phone
Moved house and tv will not tune into inside
You could try a 15dB UHF amplifier that will usually feed upto 2 TV's they cost about £10-15 and usually have a pass through 240V plug and will work with the Sky Magic Eye.
Mar 18, 2010 | RCA Mikomi 5290925 15 in. LCD TV
Env2 got wet, front keypad having problmes, "o.k" button doesn't work can I remove front cover, how??
This just happened to me last night. I FIXED IT!
The bottom half was working, the top keyboard was not working. The only button on the top that worked was the power key. Today, I got a screwdriver and took the whole entire thing apart. Start by removing the battery, then take out the 6 back screws. Gently pull the back apart - this will be tough, do it evenly around all sides instead of getting just one side and yanking or you might break it. two of the screws on the top are accessible readily, but the two near the hinge are only accessible once the back is apart. Take the front apart with these 4 screws. dry it out with a q-tip. There should be four more screws inside - take those apart and dry clean. Pull the face off and dry the large white plate that receives all the button action. I put it all back together and my buttons worked again. I didn't even feel like I did anything to fix it because it wasn't really wet inside, i think there was just a micro-dot of moisture on that white plate. I hope it works for you. I was so excited about mine that I got on here to tell others. But hey - I also prayed about it and God cares even about the little things!!!!! Now - I've got the battery out and am leaving it out for a couple of days just to make sure that its totally drive because any water in there could still damage the phone if there is a power source. GOOD LUCK!
Mar 09, 2009 | Verizon Communications enV2 Cellular Phone
My lg chocolate = piece of **** and wont charge
i was going to say... mine did the same thing and i needed another charger. so if he decides to keep that phone tell him to get another charger
Nov 04, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Lg Chocolate's Mic
1. Check your sound settings.
2. Otherwise get the phone replaced
Aug 30, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Hinge on the LG Chocolate by Verizon
It can be fixed, however it may be expensive. I would recommend sending it to LG
Jul 07, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Lg kg800 chocolate
throw it int he bin like i did with mine
May 18, 2008 | LG KG800 Cellular Phone
Lg chocolate
learn to write in English first
Jan 24, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Charging jack
I had the exact same problem and unless you know how to open up the phone and solder the connections back, which by the way are micro in size, the phone is pretty much dead. I had to take mine in and swap it out it still barely had a warranty. Try looking up a local electronics repair shop who might be able to help, good luck.
Dec 05, 2007 | LG CHOCOLATE VX8500 Cellular Phone
LG KG800 Cellular Phone Logo
48 people viewed this question
Top LG Cell Phones Experts
kenneth njonjo
Vorked Entertainment...
IT Solution
IT Solution
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
