Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
No functions working
Main on/off light comes on but nothing else, all pipes and supply appear fine?
  • 868 Answers
Sorry but your control panel is defective in my eyes.The list of complaints generating are endless.Contact the manufacturer and see if they are refunding money for this bad mistake.It will be to your benefit.
Posted on May 23, 2008
Memorex MVD2042 Unit worked fine yesterday, but today is not functioning. Standby light does not come on, and no functions work. The unit is receiving power (not an issue with the cord or power supply). I...
unplug from any power source. leave unplug for 15 minutes some capacitors keep power for a while so leave it unplug for a while. then turn back on. see what happens.
Oct 19, 2013 | Televison & Video
N64 power light comes on, but nothing comes on the screen.
It appears that your power supply is fine (you still get a power light) however your internal game board has a problem. I realize you said that you have eliminated all the other components (very smart process of elimination) so the only thing that has not been swapped is the console itself. I think you've already come to the conclusion that the N64 needs to be repaired, and you just need to hear it from someone else. Unfortunately, the console needs to be repaired. Again, you did a great job isolating the problem, so you've done all the hard work.
Jul 07, 2017 | Nintendo 64 Console
Sharp LC46SB54U TV will not power on
It can be as simple as a blown fuse in the main power supply module, if you get not indicator light at all, then it will be the power supply has gone out, if you do get some indicator light, the 5v standby power supply is still functioning but not the main section of the power supply module. The filter capacitors look good, no bulging tops?
Sep 09, 2009 | Sharp LC46SB54U 46 in. LCD TV
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Plasma 50" acts like it has no power
is the main power switch on @ the bottom if so could have bad main fuse,or power supply bad
Jun 05, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Red light flashing, no picture/sound!!!!
HI, this unit has 3 main fuse links on the main board that may be blown. the fuse links should be check before you move further into the diagnosis stage. once you have checked the fuses and they are still in a working state, this will confirm a power supply board failure. this board provides and regulates the current flow and distribution of it throughout the entire unit. If the fuses are fine and the power supply board is damaged, the green light will come on briefly then, the main control will notice that the power supply is not functioning properly. Once the main control board senses an abnormal current, it will shut down the TV rendering the red light warning. The list of fuses to check are below. Remember, if they are fine and working, the issue will be the power supply board itself and, it will need to be replaced.
FUSE CHECK LIST--
3A 12v- fuse----(242208600623)
SM 3A 125v-fuse----(242208600657)
500 MA-fuse-----(242208611092)
PART NUMBER FOR POWER SUPPLY BOARD
(996500036816)
Please rate and god bless:)
Apr 13, 2009 | Philips 42PF9631D 42 in. Plasma Television
Main light on will not come on when door is opened/closed
For some reason, the bulbs I tested that worked somehow didn't work correctly when inserted into the door opener. We opened another set of bulbs we purchased and what do you know, the light now works. I don't fully understand as the other bulbs did work just not in the garage door opener.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Display gone, no longer functioning
Green light but no display- most likely main transformer is gone (60%), 35%- blown main fuse, 5%- bad display or power supply. You are lucky if unit is still under warranty. Solution- repair shop.
Dec 31, 2008 | Denon AVR-2807 Receiver
Gestetner 3245 No light on screen after switch on. What has Failed?
can have some defective solder in the power supply.
Check the power supply board solder.
Oct 28, 2008 | Gestetner DSm645 Digital Imaging System
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
52 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
