Question about Sharp AL-1000 Laser Printer
Sharp al 1000 shows E and 7 and hangs off
My sharp al 1000 printer shows "E" and "7" and hangs after that.plse help me to rectify this problem at the earliest.
  • 1,031 Answers
If a number and alphabeth appears alternately The copier will not function. Turn the power
switch off, remove the power cord from the
outlet, contact any authorized service
representative for overall service maintainance
Posted on May 18, 2008
Sharp AL-1000 error E7
E7 is CCD drive circuit trouble. Refer to the manual
obtainable from mauritron
Feb 21, 2011 | Sharp AL-1000 Copier
MY SHARP AL-1000 PRINTER IS PRINTNG VERY FEINT
Could be either one. Probably toner.
Apr 06, 2010 | Sharp AL-1000 Copier
Repairs of sharp AL 1000 flashaing E and 7
The scanner is not reading the white reference strip under the glass properly. You will need to clean or have cleaned the scanner optics and at least the white strip under the original glass. This strip is located under the left edge of the glass...under the scale that has the original sizing on it. The machine uses this strip on start up to reference the scanner. Simple fix.
Oct 21, 2009 | Sharp AL-1000 Copier
Sounds like the scanner is locked. Look under the scanner where the paper comes out, there is a clear wheel, turn it all the way one way or the other and that will unlock the scanner.
How can i remove H 4
Press c> photo>C>photo press 14 press start/Print key
machine ok
Oct 08, 2009 | Sharp AL-1000 Laser Printer
Reset drum cod
The codes are C Auto C Auto display off, press 24 print 7 print , 00 will display then press C twice.
May 06, 2009 | Sharp AL-1642CS Copier
Sharp AL-1340 Scanner hangs up, grinding sound, with E-7 code
The scanner rails will dry out. Try a drop of oil on the rod the scanner travels on. There are two bushings that slide along the rod/rail. Good luck.
Nov 10, 2008 | Sharp AL-1000 Copier
Error on sharp copier
That has to do with the laser unit and/or the white shading plate.
First remove the platen glass and clean the white strip on the bottom side. BE CAREFUL FOR THE GRAY OR BLACK LINE ON THE STRIPE IF YOU WIPE IT WITH A SOLVENT AND REMOVE THE LINE YOU ARE DONE.
If the unit is making a whining noise it is probably the laser unit polygon motor.
If the scanner mirror system is hanging or not returning to home position check to see that the scanner lock on the underside of the scanner where the paper comes out is unlocked.
May 19, 2008 | Sharp AL-1000 Copier
Sharp AL-1000 Laser Printer Logo
138 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
