Question about Compaq Presario X1000 Notebook
Intermittent display problem
Displays sometimes especially after putting all d screws
    Brigadier General:
  • 6,966 Answers
If when closing you have intermittent display, then chances are:
1. cold solder or loose connection;
2. part of the PCB is grounding or touching something;
3. misalignment of board causing #1;
It is a physical/mounting problem and not electrical in nature. Sometimes it help putting some sort of adhesive to the back of the board to keep it in place when closing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 18, 2008
  • 300 Answers
There's a small plunger just beyond the keyboard which switches the screen off when you close the laptop, this could be sticking. Failing that check the screen cables are secure, reseat the screen
TV intermittently does not display picture. Back-light and audio are OK.
if reseating connectors and ribbons (assuming you've cracked the case open yourself and gotten your hands dirty...or atleast scratched up lol) then I would have to say it sounds like an issue with the logic board or maybe a particular component overheating? it sounds tedious but grab yourself a magnifying glass and look at your individual capacitors and resistors for any physical damage especially what I call, "bursting....." where it looks like they're puffed up and popped from the inside.. sometimes a capacitor will blow and not completely lose it's top so it works intermittently the same with resistors in my experience.... hope this helps.
May 09, 2016 | Samsung 50" Class 1080p 120Hz Smart LED...
2006 trailblazer factory installed DVD has sound but no screen. The screen intermittently comes on, it stays on once it works but if we turn the vehicle off, we get the intermittent behavior. Has an
the factory dvd decks are designed to disable the dash display when the car is running, to negate distracted driving. the factory wires the rear seat dvd displays only to work when car is running, and the dash to work only when the car is either acc, or, possibly, in park.
if the dash is intermittent, and, especially, if the dash display has some dvd video while running(or, more dangerously, when in drive) then a previous owner likely tried to bypass this safety feature by crossing wires under the dash, and did a poor job.
otherwise, lcd screens can become intermittent, in regards to powering on or off, if the backlighting regulating circuits start to fail. this would be an issue with the deck itself, and is merely due to old age (nearly 8 years)
. the hallmark of this problem would be if you were to hold a flashlight to the screen, and see a faint display,- simply lacking the florescent back-lighting.
Dec 28, 2014 | 2006 Chevrolet Trailblazer Ext
Furnace intermittent on Comfort Control
It depends on what mode the unit is in when your looking at the screen. No call, no display. No errors, no display
Apr 11, 2014 | Dometic Heating & Cooling
White screen or some times white vertical lines at start up
I had similar problem. Sometimes the screen goes white while working under windows and repositioning the display, but most of the time it goes white during power up. I decided to check the display cabling by removing the speaker/power-button panel and display coverings. Although I couldn't find a loose cable, the display was consistently working properly. I put it back together and so far so good.
To expose the wiring:
1. Power off, unplug power cord, and remove battery.
2. Open display all the way flat with the keyboard.
3. The speaker/power-button panel is also the cover for the display hinges. You can pry the panel off by prying up the hinge covers from the sides facing center.
4. The inside display covering is fasten with four screws in the corners covered by the rubber bumpers.
5. The outer display shell is attached by 6 screws. 2 on each hinge and 1 on either side of the LCD unit.
6. The mic and camera cables can be unpluged by gentle prying the plugs out.
Jul 10, 2009 | Acer Extensa 5420-5687 Notebook
Blank screen with lines
The main logic board is bad. Probably an intermittent connection between the MLB and display interface, or the BGA chip needs to be reheated. Try banging it on the table, or twisting/torquing it. Loosening the screws can help sometimes, or just taking it apart and reseating all the connections does the trick.
Aug 10, 2008 | Intermec 700 Series Mono Mobile
No Display sometimes
MAKE SURE THAT THE VIDEO CABLE IS TIDE AND CHECK IF THE MOBO IS NOT GROUNDED I SUGEST TO RESET THE MOBO AND TRY TO PUT SME ISOLATION IN THE SCREWS
Aug 03, 2008 | Intel Motherboard
Inspiron 8500 - Display issue
with the external monitor attached press <FN><F8> to toggle between internal and external display. if still nothing then it sounds like the video card.
MANUAL
Check all the connections (especially the ground screws) that was a problem with one I worked on last year.
May 29, 2008 | Dell Inspiron 8500 Notebook
Compaq Presario X1000 Notebook Logo
50 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
