Question about GMC 2003 Envoy XL
Check engine light on - 2003 gmc envoy XL
My check engine light (white light) has come on inside my 2003 gmc envoy XL? I took it to auto zone for the free reading and was given a code 0128. They think it maybe the thermostat or the coolant temperture sensor. The car is not over heating and it drives fine. Does anyone have any knowlegde on this problem or where the sensor maybe located? Thanks coolant level is fine and the code 128. thanks
  • 12 more comments
  • jmb4810 Jul 28, 2008
    I took my 2003 envoy truck to get checked for possible water leakage. I was told my theromastat was bad and needed replacing. What is the average cost and does the Envoy have a double thermostat?
  • beybgyrl2000 Sep 07, 2008
    i have the same problem. My light comes on for a week or so then it goes off and comes back on in approximately two days. I took it to auto zone and they told me the same thing about the themastat sensor. But having trouble with my mechanic finding it to replace it
  • Lizarrd Sep 10, 2008
    I had my 2003 Envoy checked out too and received the same code. I ordered the part through Pep Boys and after 3 weeks was told it was not in stock. Does anyone know where this part can be ordered?
  • tturtle Oct 26, 2008
    Trying to replace the tthermostat , I have a Haynes repair manual. It Tells you to remove the alternator then follow the upper radiator hose to the engine, this hose is nowhere near the alternator its on the opposite side of the engine. So where is the thermostat on the engine of a 2003 Envoy with a 6 cylinder 4.2 L engine
  • Anonymous Nov 09, 2008
    My service engine light is on, the truck runs fine. It would not pass inspection, I was told it ws the coolant temperature sensor. I picked one up t Advance auto parts but I cant find it on my truck. Anybody know where it is located? I have a 2002 GMC Sonoma ext.cab 6 cylinder pickup. Thanksw.
  • ej_q29 Dec 07, 2008
    2003 GMC ENVOY 2WD 4.2 L Dianostic code 128
    Engine Coolant Temperature (ECT) sensor monitors the temp of the coolant.
    After several week of getting the "Service engine soon ligth" I decided to get a dianostic on my envoy resulted on ECT code 128.
    I will try to check the thermostat since my temperature gauge reads 168 F and is not moving at all and I think my thermostat is not regulating i'm assuming that is stuck open.
    my next try will be to replace the ECT sensor.
    Thanks for the previous people for the location of the thermostat.
  • Anonymous Dec 13, 2008
    I live in the city and only drive on the highway every so often, and thats when the light comes on. after a few days of coty driving it goes of again.
  • Anonymous Feb 06, 2009
    where is the coolant temp sensor
  • Anonymous Mar 20, 2014
    the service engine light is flashing on my 2003 envoy? what can it be?
    where is the headlamp driver module located on a 2002 gmc envoy xl
  • Anonymous Mar 21, 2014
    Light service is on.Took to auto zone to check. They said it was a leak in the evaporator hoses
  • Anonymous Mar 25, 2014
    when I replace the camshaft sensor in my 02 envoy the old sensor was wet. I put the new one in and now the service engine light is flashing. what did I do
  • Anonymous Mar 30, 2014
    sdascacasc
  • Anonymous Apr 01, 2014
    Stalls when stopping at a light starts right back up runs fine
  • 375 Answers
That code represents a lower than expected reading for temperature (coolant). First thing to do is check your coolant level, as if it is low, then the sensor can not read correctly. Second, you may have a thermostat that is stuck open, allowing the coolant to cool off too much. The sensor should be mounted on top of the engine, near the thermostat housing.
Posted on May 18, 2008
On 2004 gmc envoy's the thermostat sits behind the alternator if looking at the engine its on the right side. its hard to get to but if your patient and move a couple of wiring harnesses you can get to it thats also where you'll find the t-stat sensor but try the thermostat first if your temp isnt getting too high usually 210 is normal any higher then its over-heating and that could be the water pump or thermostat if its less than 210 then its staying open,
Posted on Oct 08, 2008
The temp senser and the thermostat are located on the right side of the engine under the alternator. The alternator will need to be reoved for access.
Posted on Aug 23, 2008
The temp sensor is located next to (forward) of the thermostat housing, which you can find by tracing the upper radiator hose back from the radiator to the top of the engine. The sensor will need a special tool for removal or a 15mm wrench if you are patient. When you replace it you will see why I say patient.
Posted on Jan 25, 2010
2005 GMC ENVOY - Same problem as stated before however i had a loss of power when going up hill. Could this still be the same problem or is it something else????
Posted on May 25, 2010
Why doesn't the air conditioning work?
New owner of 03 Envoy XL SLT - AC not working - Chevy TrailBlazer ...
forums.trailvoy.com > ... > OEM Issues
Apr 12, 2011 - 11 posts - ‎5 authors 2003 GMC Envoy SLT XL Summit White ... My Envoy XL SLT has the I6 engine, digital driver/passenger, and rear heat/AC controls. When I looked at it, .... There have been reports of failed sensors in the compressor. Can you ... [SOLVED] Rear A/C blower 03 Envoy XL
May 22, 2011
XL rear a/c problem - Chevy TrailBlazer, TrailBlazer ...
Jul 31, 2009
Air Conditioner Problem - Chevy TrailBlazer ...
Aug 17, 2008
Blower Motor/Module? Problem - Chevy TrailBlazer ...
Mar 9, 2007
More results from forums.trailvoy.com
Jul 18, 2015 | GMC 2003 Envoy XL SLT
MY 2003 GMC ENVOY HAS HAD THE CHECK ENGINE LIGHT ON FOR A WHILE.. DID SPARK PLUS, OIL CHANGE, FILTER. TOOK IT TO ADVANCE AND IT SAID THE CRAM SHAFT SENSOR WAS BAD... BUT IF IT WAS BAD.. DOESNT THAT MAKE...
No your car will still turn on with a bad cam sensor. Bad crank sensor would cause a no start. What code is popping up with the check engine light?
Feb 24, 2015 | 2003 GMC Envoy Xl
Engine warning light comes on
check fluids take it to auto zone they will put it on computer for free most likely its an O2 sensor easy fix
Jan 25, 2013 | 2005 GMC Envoy Xl
2003 envoy smells like fumes and idles rough
have you checked for a vacuum leak?pcv attached,no leaks around plenum,engine coolant temp sensor reading right.
May 31, 2012 | 2003 GMC Envoy Xl
2003 gmc envoy xl 4wd 5.3 litre idles low and stalls mainly when parking but sometimes also when coming to a stop...have replaced many parts already.
Hello: Get some carburetor cleaner, remove rubber tube going to the throttle body. Spray cleaner on rag and open throttle plate and clean all black stuff (carbon) off the throttle plate and the inner bore of the throttle plate. Make sure its clean, You can spray some in the throttle body but not very much as too much and you cab blow the engine up. If build up is bad (carbon) go to Auto Zone and purchase a small brass bristle brush to help remove carbon.
Oct 24, 2011 | 2003 GMC Envoy
I have a 2003 GMC Envoy and the check engine light comes on peridically. Auto Zone checked it and Code 0128 was the alleged issue. However, where is the sensor? No one seems to know the location of the...
This code relates to low coolant temperature not the 02 sensors. You should change your thermostat, it's stuck open and is not allowing the engine to properly heat up.
By the way, there are 2 92 sensors on Envoys and Trailblazers. One of them upstream is in the engine compartment right off the exhaust manifold, easy to replace. The other one downstream is next to the transmission drain plug in the exhaust pipe.
Oct 26, 2010 | 2002 GMC Envoy XL
My 2003 GMC Envoy XL's check engine light is on and idles rough. I suspect an O2 sensor and was wondering if a person can buy an analyzer to heck it themselves instead of paying a mechanic? Richard
You can take your vehicle to a place like Auto Zone, they can read the fault code with scanner, or you can buy a OBD II scanner for anywhere between $50 to $100. Interpreting the codes may require some knowledge of the car though.
Apr 18, 2010 | 2003 GMC Envoy Xl
Service engine light is on
if its a 6 cylinder the sensor is located on driver side behind the alternator .the sensor alone is about 80-100 dollars. but it is difficult to get to if you dont know what you are doing. the shop should charge you 150 to have this done.
Apr 19, 2009 | 2003 GMC Envoy Xl
Coolant Temp Sensor
The sensor is located on the drivers side engine block...although you can see if from looking from the top of the engine, you would have to get under the vehicle and look up to replace it. Be aware that it takes a special tool to unscrew the old one and screw in the replacement.
Aug 06, 2008 | 2004 GMC Envoy
GMC 2003 Envoy XL Logo
7,623 people viewed this question
Top GMC Computers & Internet Experts
Alun Cox
bigdawg7299
Jeff Armer
Are you a GMC Computer and Internet Expert? Answer questions, earn points and help others
