Question about Russell Hobbs 10617 Glass 2-Slice Toaster
How to take apart a Russell Hobbs 10617 Glass 2-Slice Toaster
The raising & lowering handle mechanism has become loose. As we have found a screw, I suspect the chrome/wood inserted handle is becoming detatched from the toast support bar.
How do I actrually take the Toaster apart ? There does not appear to be standard screws in the base. The problem is getting access to the link between the handle and toast support bar.
Thank you
Ken Prosser, Adelaide South Australia
  • chloe1910 Dec 01, 2008
    russell hobbs 10617 glass 2-slice toaster
Falling Down
  • 67 Answers
SOURCE: Russell Hobbs 10617 led bar
may have screws on the bottom and the loader knob usually has to be pried off. Place soft wood like a ruler against the housing and pry carefully from side to side with a large screwdriver. After working on it, plug it in outside to a ground-fault ac plug on a fireproof surface to test.
Posted on Nov 30, 2007
  • 537 Answers
SOURCE: Russell Hobbs Toaster Model # RH4T9379
It would be NICE if you didn't abort the chat session when I was tyring to help you. Geez!!
Posted on Dec 03, 2007
SOURCE: russell hobbs toaster 9379 bread carriage handles
bought a new toaster I would like any account you have created for me to be deleted. thank you
Posted on Dec 23, 2009
SOURCE: What is the part number
The ICU is a 16C56-02 microprocessor. However, I don't think you can just swap chips - it has to be programmed first, so unless you have an eprom and know the correct code....
If all of the lights work, and the toaster works, but the lever doesn't stay down (seems to be the common issue), I would try resoldering the transistor legs on the circuit board. The transistor is used to switch the magnetic solenoid that controls the lever. Mine had a cold solder joint, and when I resoldered, it worked fine. Wouldn't be surprised if they put out a whole bunch of boards with the same issue. Good luck.
Posted on Sep 04, 2010
mc1bean
  • 3053 Answers
SOURCE: how do u change the toasting (1 to 6) knob on a
Hello, thebrownesI was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Russell-Hobbs 18140 4 slice compact toaster
See the diagram attached:
You will see the fuse you will problema 1) Ground 2) Live wire touching the chassis 3) Heating elements in short 4) Control Relais in short. 5) Test Diodes,You must test every components.God bless you
May 17, 2012 | Russell Hobbs 18140 4-Slice Compact...
I have a 10617 2-slice glass toaster which has recently had 4 leds permenantly on. I cannot lower or increase this. Also, the lever will not stay down.
Hello, jon
Thanks, Mike
Sep 16, 2011 | Russell Hobbs 10617 Glass 2-Slice Toaster
I need a user instruction manual for a Russel Hobbs RHM25L Microwave Oven
You can download the instruction manual by clicking on the following link.(http://www.russellhobbs.co.uk/pdf/product_236_14356.pdf ).Please don't forget to rate me if satisfied.Good Luck.
Jun 08, 2011 | Russell Hobbs 10617 Glass 2-Slice Toaster
Russell hobbs toaster 9379 bread carriage handles won't stay down to toast
Dec 22, 2009 | Russell Hobbs 9379 Classic 4-Slice Toaster
My toster does not ssstay in ON position. The IC with mark 63AB1B (2x9pins) probably broken. Can somebody tell me what is this IC and where I can get its datascheet. I tried internet with the number...
An integrated circuit constructed to provide control functions to a toaster oven cooking appliance. The control functions including compensation for input voltage fluctuations, compensation for residual heat due to recycling, audible signal generation, multiple mode selection, safety shut off and others. The integrated circuit also provides flexibility to accommodate multiple models of an appliance in a product line. If you have the tools and the part, you can fix it yourself otherwise to the repair shop
Oct 29, 2009 | Russell Hobbs 10617 Glass 2-Slice Toaster
Microwave does not heat food up. Oven bakes perfect cakes.
Check magnatron Fuse (The big one) if not probably the magnatron tube.
Aug 11, 2009 | Russell Hobbs 10617 Glass 2-Slice Toaster
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
User Manual
Here's a user's manual from Russell Hobbs that gives preliminary steps for a very similar product. It is in PDF form.
http://www.russellhobbs.co.uk/pdf/product_57_10617.pdf
Jan 27, 2008 | Russell Hobbs 10617 Glass 2-Slice Toaster
Nov 01, 2007 | Russell Hobbs 10617 Glass 2-Slice Toaster
Russell Hobbs 10617 Glass 2-Slice Toaster Logo
196 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
