HP Deskjet F2100
Will not turn on. Have disconnected, reconnected and tried in other power outlets to no avail. Only bought the printer in January.
  • 19,396 Answers
Check power cable first
Posted on May 18, 2008
  • Ginko
    Ginko May 18, 2008
    If the printer does turn on and then does not print, there may be several causes for this. If it does not turn on at all, then the printer is not getting any power. Check first the power cable, by replacing with a similar one. If you are in uk you can also check the fuse in the power plug.
    If it is not the cable then it is the power adapter that is faulty.
    Don't try opening the printer. Check you guaranty termes, you may have 1 year from HP, contact also the retailer. If you take apart the printer you will invalidate guaranty.
My printer is hp deskjet 4625 fls advice me. there is a problem with the printer or ink system. turn printer off, then on. if problem persists, contact hp error. 0xc 19a0022
You may try to reset the printer. I was not sure if you followed these steps and unplugged the power cord. That may fix your problem. Good luck this can be very frustrating.
In some cases, a printer reset can clear the error message.
  1. Turn the printer on, if it is not already on.
  2. Wait until the printer is idle and silent before you continue.
  3. With the printer turned on, disconnect the power cord from the rear of the printer.
  4. Unplug the power cord from the wall outlet.
  5. Wait at least 60 seconds.
  6. Plug the power cord back into the wall outlet.
    NOTE: HP recommends connecting the printer power cord directly to the wall outlet.
  7. Reconnect the power cord to the rear of the printer.
  8. Turn on the printer, if it does not automatically turn on.The printer might go through a warm-up period. The printer lights might flash, and the carriage might move.
  9. Wait until the warm-up period finishes and your printer is idle and silent before you proceed.
Apr 13, 2016 | HP Office Equipment & Supplies
Hp laserjet 1020 meltdown
Try this out:
Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
  1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
  2. Disconnect the power cord or adapter from the wall outlet.
  3. Disconnect the printer data cable from the printer.
  4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
  5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
  6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
  7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
  9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
  10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
  2. Disconnect the power cord from the wall outlet.
  5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
  8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
  9. If the power cord works on the other printer, then this printer is defective. Service your printer.
  10. If another printer is not available to test with, carefully inspect the power cord for damage.
  11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | HP LaserJet 1020 Printer
I dont have installation to instALL MY f4280 DESKJET ALL IN ONE PRINTER, I NEED TO INSTALL IT ON MY COMPUTER, WHAT DO I DO?
  • Lets’, see if this fix it.” Turn off your (Computer), turn off the (Printer), unplug the printer from the power outlet; do not make any changes to the computer. Disconnect (all) the printer cables from the computer; reconnect the cables to the computer, and plug-in to power outlet. Turn on the computer (first), turn on the printer. Go to; Control Panel, (Hardware and Sound), click Printer; if the Printer is present; click to open, Properties, click (Drivers): Update Drivers. Restart computer. “I hope this, Fix it.”
Feb 20, 2010 | HP DeskJet F4280 All In One Printer InkJet
I cant install the driver of HP Deskjet F2100 series, HP Deskjet F4100 series printer to my new PC which is Windows 7
Are you trying to use the CD? If so go to HP.com/support and see if there are Windows 7 drivers available for the printer (be sure to note whether you have 32 or 64-bit Windows 7).
Feb 06, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
All lights flashing fast on HP 5150
Sounds like your DeskJet 5150 needs to be restarted. Try:
1) Press <Power> button to turn the printer off, then press again to turn it back on
2) If problem persists, turn off the printer
3) Disconnect the power cord from the power source
4) Reconnect the power cord
5) Turn the printer on
Dec 21, 2009 | HP DeskJet 5150 InkJet Printer
Printer will not print
Disconnect and turn off your printer.
Search by your printer model number and download latest drivers from here:
http://h10025.www1.hp.com/ewfrf/wc/siteHome?lc=en&dlc=en&cc=us
Start installation of drivers and connect your printer ONLY when the setup asks to connect your printer.
If it gives you any warning about "driver signature", just click on "continue anyway". After completing the installation, your printer will work fine.
Jan 05, 2009 | HP DeskJet F380 All-In-One Printer
Hp deskjet f2100 problem
ok..remove all printer software first
go to www.hp.com and get fresh drivers for your model and operating system
then reinstall it..
http://tinyurl.com/6qcpgy
Aug 16, 2008 | HP DeskJet F380 All-In-One Printer
HP Photosmart 7350 Printer Carriage Cradle is jammed
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Jun 20, 2008 | HP PhotoSmart 7350 InkJet Printer
HP deskjet F2100 series printer
i bought hp deskjet f2100 series printer and automatically driver was curupted from my system and now when i am trying to reinstal it again it shows error no hp printer found ...so please give me solution
Oct 10, 2007 | HP PSC 1610 All-In-One InkJet Printer
48 people viewed this question
k24674
jasbo
jasbo
