Question about HP Office Equipment & Supplies
HP DeskjetF2100 will not turn on. Have tried it in other power outlets to no avail. Only bought it in January.
    Brigadier General:
  • 6,966 Answers
Since it was only January, then perhaps you can claim warranty. Problem could be anywhere from the fuse, AC cord or AC adapter, power supply and a few other more.
Should you prefer to do a DIY, this would require that you be familiar with electronics circuitry and components, the use of a DVM and probably even a soldering iron. Should you wish to venture a user electronics repair, pls post back.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 18, 2008
  • Louie  Role
    Louie Role May 18, 2008
    Hi again,
    Your particular model comes with an external AC adapter that is powered from the mains and provide the low voltage supply for the printer. This is made up of three parts; the AC cord, the adapter itself and the output cord. You need to check the continuity of both cords and a voltage output of the adapter. A DVM would be required.
    President:
  • 1,944 Answers
Does the printer show any signs of life when you plug it in?
  • Damen Wong
    Damen Wong May 18, 2008
    Does anything light up for a second? Is there any noise?
HP Deskjet F2100
Check power cable first
May 18, 2008 | Office Equipment & Supplies
Sanyo tv turns itself off
Power supply failure
Jan 29, 2014 | Televison & Video
Hp PSC1210 All-In-One not turning on
HP makes a couple of different power cords for the PSC 1210 and their other printers. First make sure you are using the correct power cord (Amperage and voltage). Unplug the power cord (from the wall and the printer and from a power module if you have one). Leave all of the sections unplugged for at least 15 seconds to reset the power module/printer.
Next connect the power cord to the wall outlet and to the power module if present and check if the LED (if present lights up). If it doesn't try another outlet. In either case, check what the outlet voltage/amperage is at the end of the power cord with a multimeter (before you plug it into the printer). If you have a power module, then check the Amperage (it will be a DC current out).
If you are not getting the correct voltage and amperage out or the LED doesn't light (with a known good outlet), try a different power cord/module.
You can order these from HP.
If you have the correct power at the cord, plug the power cord into the printer and attempt to turn it on. (Press and release the power button.) If the printer still doesn't come on, the unit needs service. Contact HP if the printer is under warranty. Decide if it is worth fixing if it is out of warranty.
I hope this helps.
(I've had to use the HP Repair/Replacement service after a unit was in a home that was hit by lightning. Due to printer availability, an HP gift card was provided to buy a new printer.)
Dec 11, 2011 | HP PSC 1210 All-In-One InkJet Printer
My tv won't turn on... Its pretty new, just bought it in January. No lights, no nothing. Yes it was plugged in, yes I have electricity running through my outlets, yes I've tried it in other outlets, yes my...
Sounds like the power supply is bad. If you purchased the unit new in January 2011, contact Phillips for warranty repair. Call 1-866-771-4018 between 8 am and 11 pm Monday through Saturday or 9 am - 6 pm Sunday. Have your model number, purchase date and serial number ready. New units have a 1 year warranty.
If this was a refurbished unit, the warranty is probably up (only 90 days). Replacement power supplies may be available on line. You will need to open the TV to get the current part number to get a matching one. I see a few listed at shopjimmy.com http://www.shopjimmy.com/catalogsearch/result/?q=47PFL6704D . This site specializes in minimally used parts (from TVs damaged during shipping).
I wish that I had better news.
Apr 30, 2011 | Philips 47PFL6704D LCD TV
Power could not start by pressing power button but power is coming as the blinking is done for once when connected to power
Solution one: Make sure the electrical outlet works
  1. Unplug the power cord from the electrical outlet.
  2. Plug another appliance into the electrical outlet to make sure the outlet works.
    • If the electrical outlet does not work , plug the product into another outlet that does work.
    • If the electrical outlet works, but the product still does not turn on , continue to the next step.
Solution two: Make sure the power supply is compatible with the HP product
Follow these steps to test the power on the product.
  1. Reconnect the power supply to the rear of the product.
  2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Test the power with a compatible power cord from a different product If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
  • If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
  • If the product does not turn on with the alternate power cord, continue to the next step.
Solution five: Service the HP product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 30, 2010 | HP DeskJet F380 All-In-One Printer
I have installed deskjetf2100 .
i think you are useing the refill carteg just install org carteg in your printer
Jul 15, 2009 | HP PSC 1610 All-In-One InkJet Printer
For some reason my deskjetf2100 will not print
restart ur pc and try... it shd print... else u will have to go thru the printer options also chk with the ink level...
Sep 13, 2008 | HP DeskJet F380 All-In-One Printer
18 people viewed this question
Seeker5211
Seeker5211
