Question about HP PSC 1315 All-In-One InkJet Printer
Papaer jam when I give a print,or take a copy by using my hp 1315 all in one it not working properly. The complaint nature is the paper strucking.After taking half of the paper inside, the papaer is strucking and the printer shows a message that" mechanism Error", printer cradle cannot move. At that time the position of the catridge is at the right side of the printer. It cannot move to the left side.I unplugged the catridges,and replugged it. But the complaint still exists. what is the solution? pl send the solution to my mail Id. My id is , prasad_keltron1@yahoo.co.in thanking you, prasad.v
  • vipviper Jun 17, 2008
    the same proablemm with paper jam, no need of description.
  • cask Jul 05, 2008
    when I give a print,or take a copy by using my hp 1315 all in one it not working properly. The complaint nature is the paper strucking.After taking half of the paper inside, the papaer is strucking and the printer shows a message that" mechanism Error", printer cradle cannot move. At that time the position of the catridge is at the right side of the printer. It cannot move to the left side.I unplugged the catridges,and replugged it. But the complaint still exists. what is the solution? Send solution to cask@lantic.net
Same thing happens to me
Posted on Jun 30, 2008
Papaer jam in toshiba e-studio 181
try changing the paper u use..... i recommend typex or xerox...
Apr 02, 2012 | Toshiba Office Equipment & Supplies
Change papaer size and frequent papaer jams
OK it seems to be a problem with pick up clutch and vertical feed rollers ( When you open the left door and hinge in level of cass you will see axis with the tree little rollers- clean it with alcohol or water).Pick up clutch is better to replace it FK2-1068 (europe code).
Jan 12, 2009 | Canon iR 2016i Black and White Copier
FUJIFIM Premium Plus Photo Paper 235 g/sm Jams when printing.
Fuji paper is the arch enemy of the hp printer due to it's high gloss and the slickness of the paper - try another brand of paper. It sounds like a money grab but hp paper has a special marking on each page that is read by the printer and it often errors much less.
Jul 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
my printer no function cant print
Jun 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
Troubleshooting on hp printer/scanner/copier
This looks like either there is an paper jam or carriage jam on the unit,
Check the rare access door weather there is a paper jam.
Remove the cartridges and try moving the carriage( the cartridge hold) left to right and right to left and check if its moving freely.
After these try disconnecting the power cable without turning off the unit and hold the On button for 15 secs and then plug in the power cable while your hold the on button.
This should probably fix the issue.
Please do let me know if there is still an issue.
Feb 19, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 paper jam.
does it turn on or doesnt pick up the paper?
Oct 28, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
103 people viewed this question
Ben Johnson
