Question about Baby Gear
My mic is detected... sort of
My microphone is detected by soundmax. but when i try using it, it doesnt work. when i go to set it to default sound recording device, its name isnt there. i even restarted my computer. any file i need to download?
    Genius:
  • 3,422 Answers
All you have to do is right click on the speaker icon which is next to the soundmax icon in the taskbar and select the" ADJUST AUDIO PROPERTIES"
Now select the voice tab and in that under the VOIC3E RECORDING click on vloume and make sure the microphone volume is full now close it and click on Test Hardware.
Goodluck.
Posted on May 19, 2008
Is there a microphone on a labtec 1200, the box says there is, the webpage doesnt say anything, my windows xp with service pack 3 cannot detect any microphone,
To check
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Aug 02, 2010 | Labtec Logitech 1200 Webcam
The microphone cannot be detected and the SoundMax
Hello
It could be as simple as needing to reinstall your sound drivers.
Also try going to control panel,sound, click on sound be sure your device is listed.
Go to the propeties tab find levels scroll down to the bottom to microphone.Turn it up.
Also make sure your in the right input on your motherboard or back of the pc.mic is usually coded as pink.
Hope this helps.
Jan 22, 2010 | HP Compaq d530 CMT PC Desktop
Clear chat mic doent work
in skype go to tools>options>audio setting make sue the microphone is logitech and the green bars should start moving as you talk.
if no logitech appears or the mic is not producing sound. call logitech for warranty info. if the mic is producing sound below is "make a free skype test call" to see if the program is transmitting.
Jul 18, 2009 | Logitech ClearChat Stereo Headset Headset
Crackling Microphone
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-78911-1
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
Hope can help
Jun 19, 2009 | Logitech (980240-0914) Consumer Microphone
Cannot recognize working microphone
I found the answer. Rosetta Stone has a problem detecting the mics if the speaker input is not in someway connected to the mic. I'm not exactly sure how it works, but I don't care and neither should you.
Follow these steps each time you want to use it and you should be fine.
*I'm on Vista, but this should work for every one.
1. Open Control Panel
2. Open Hardware and Sound
3.Open Sound
4.Set Line 1 as your Default Speaker
5. Refresh the Mic list
*All of your mics should now show up.
6. In Rosetta Stone, apply the mic you want and finish the setup.
7.Start whatever language you're using and switch back to the Sound menu.
8.Set whatever speaker you want to use as default.
*Rosetta Stone will continue to work fine until you close it, switch Users, or remove the mic.
In short you have to set the default speaker to LINE 1 to get the mics to appear. Then when you apply the settings switch the default speaker back.
Apr 21, 2009 | Computers & Internet
Soundmax microphone error
Check your front panel connectors are wired correctly :)
Nov 14, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Microphone is not working windows vista
My microphone has always worked on vista for, I use it everyday on skype, but today it will not work, I can hear the caller but they cannot hear me. I thought my headset was broken and i bought a new one. but its still doing the same thing with the new headset. It says the microphone settings are enabled and working, but when i do the mic test, it says that it cannot hear me.
what can i do?? help!
Dec 27, 2007 | ASUS M2N-E SLi Motherboard
Microphone port not working
in advanced settings there would be options for microphone boost and something else...disable both...i dont know the reason why this happens but mic doesnt work with those options enabled....
Dec 05, 2007 | ASUS A8N-VM Motherboard
Michrophone
which program are you useing?
its possible your mic is on mute so no sound gets throught.
check the speaker icon next to your clock
then press settings and properties and click on regording. then ok. then make sure the microphone is not muted and the sound level is high enought.
Oct 14, 2007 | Logitech USB Desktop Consumer Microphone
Baby Gear Logo
35 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
