Question about Asko Dishwashers
1502 NO POWER TO PANEL
MY ASKO 1502 NO POWER SUPPLY TO PC CIRCUIT BOARD,COULD YOU PLEASE PROVIDE SOME WIRING DIAGRAM?THANKS A LOT!
E-MAIL: prodohu@hotmail.com
The wiring diagram is INSIDE the metal casing behind the lower kick panel. It is a paper schematic that details the wiring of the dishwasher. Mine was pretty water logged and crusty. Just unscrew the kick panel. It should be right behind it
BTW: Ours also lost power to the panel last week. It's interesting that the production date of our Asko is from 1988. Exactly 20 years. Asko's warranty is also exactly 20 years. Coincidence? Don't bother trying to replace the board. Asko discontinued it and it is no longer available.
Posted on Jul 08, 2008
Jenn air sve47600w
with wiring diagram check to see if any power to circuit board. check any limit switches in line in oven circuit. then check the following.sounds like a circuit board problem. turn power off for a minute then try again. also with power off unplug all connections to board and plug back in. if still problem replace electronic oven control board.
Nov 16, 2013 | Ovens
Need circuit diagram for pd2171 23590258B power supply
What is the main problem in the power supply...? if u need any part no, pl send us the mail with pic, we can send u the part no's.
Jan 23, 2013 | Toshiba 32WLT58 32 in. LCD Television
ASKO t760 will not heat. I pressed the high temp reset button on the back but still not heating. The manual talks about a test program. But it says you need to "short circuit the outputs ST4-1 and...
Hello, welcome to FixYa.
Based on your description I`d be curious if you have checked the wiring diagram on your Asko dryer, it is a T760 correct ?
The reason I'm inquiring to this is I have a diagram but there is no mention of these ST4-1 and ST4-2, though my experience would suggest they are located on the board for the "safety thermostat" (ST) and it would simply be to by-pass the safety to rule it out of the crcuit.
I don't know what other actions you may have taken to check the element, but there is a way to physically check the heating coils, though it requires removing the back panel but I have a service manual I could provide you or guide you how to.
Keep me posted on what you find or if you want the servie manual (which I'd have to provide email and would need an email address...it's your call) I'll help in whatever manner I can. Good luck.
Regards,
Macmarkus :)
Jun 25, 2011 | Dryers
I was expecting to find this relay. It's not there. My unit has a rather complicated looking circuit board. The circuit board seems to have been made by Emerson Climate Technology. On the top edge of...
this board needs a 24 volt supply run from the furnace to power up the communicating board
check your wiring diagram on the inside of the panel this will help you
Apr 04, 2011 | Amana Heating & Cooling
Stuck in the dry cycle
defect in main panel .....call for service ...
Jul 25, 2009 | Dishwashers
Replace atx 250 12e power supply with 350watt power supply per
Sounds like there maybe some kind of problem with *********** board connector. Double check that it is the right size, and be sure there are no places that still need power. When you get the chance I'd check the following:
Disc Drives
Motherboard
Floppy
Hard Drives
That all cards are secure, if there are any loose connectors your comp will declare "short circuit". At that point, unplug the cord from the mother board (the power cable) and try again.
Any USB Cables
Anything that looks loose, and finally, recheck the compatibility with your system.
Good Luck!!!
Jun 01, 2009 | E-Machines eMachines Desktop PC
HCL HCM780M CIRCUIT DIAGRAM
SIR..., regarding monitor...display block characteristics which is operated manually by buttons situated bottom of monitor is anytime coming at the centre of monitor display... The settings block comes on suddenly and we are unable to exit from the same sometimes the block goes off without any action and everything is fine till it is back again and it is come again and again.....by all this i did'nt work on my PC...all result it's useles......please sir giving your suggestion as soon as possible....... This has been happening for the last 1 year and is a real pain Please send some solution
Jan 23, 2009 | Computers & Internet
I need a wiring diagram for a asko T-700 dryer
I do not need an expert, I need a wiring diagram. If you sold wiring diagrams for the asko T-700 I would have beenn happy to purchase. talking to an expert would be of no help to me. thanks anyway.
Oct 07, 2008 | Asko Dryers
W640T2 (CIRCIUT BOARD)
I am a technician for Asko in Australia.The blackness on the motor control unit(circuit board) is probably carbon dust from the carbon brushes in electric motor.Likely problem is motor brushes have totally worn the armiture in motor or the MCU needs replacing due to earth leakage or short.Purchasing the parts from Asko should be no problem, but if you purchase and install electrical componenents only to find problem unresolved, you can't return installed parts for a refund. Also the breather hose from the detergent dispensor to outer tank can leak from tank connection when spinning load , and result in water running down outer tank and onto the electric motor causing circuit breaker to trip.....possibly damaging motor too. Goodluck!!
Sep 13, 2008 | Asko W6461 Front Load Washer
My Asea 1502 Dishwasher gets most of the way through a cycle then stops with lights flashing. It is empty of water. What is the problem?
Further to my problem with my 19 year old ASKO ASEA D1502 Dishwasher .
I found a Use & Care Guide online at the ASKO site:
http://www.asko.com.au/downloads/manuals/
(It is an 8MB PDF, only 20 pages scanned)
The manual says flashing lights in the combo I had indicate heater fault.
Manual has good test procedure and I followed that and it showed that the Heater is OK.
Machine works through full cycle but flashes at the end.
It is an old machine so I suppose I just live with it unless anyone has any suggestions.
Apr 23, 2008 | Dishwashers
Dishwashers Logo
327 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
