When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
Let me know what error code you find, I will tell you what it means.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
THIS WAS NOT HELPFUL BECAUSE I COULD NOT CLICK ON THE SOLUTION. ALL I GOT WAS FACEBOOK OR A POP-UP FOR BLACKBERRY.
THANKS ANYWAY
complain to the site, [email protected] just of course work here
