posted by aceraspire55 on May 18, 2008
hello..at first i wasss trying to figure out how to fix the webcam of the yahoo messenger.now,while i was trying to figure it out,i accidentally uninstalled my crystal eye webcam..my unit is acer aspire 5520.pls help me.
Solution #1
posted on May 18, 2008
There is a driver, and an application available from Acer for this webcam, for each different operating system.
Goto:
http://www.acerpanam.com/synapse/forms/acerdrivers.cfm
And select your 5520. This will lead you to a PDF document with links to the pairs of driver/app for your operating system. If you have XP, Download the XP driver and the XP app and download them to your desktop.
Goto the control panel, and into the device manager, and make sure this webcam is completely uninstalled.
Then install the web cam with the driver. Use windows add hardware wizard.
The cam should then be available in all programs that support webcams.
Goto:
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
Acer (91.97420.A14) Micro ATX Mini-Tower Case
Acer BG 95 (91.00634.030) Baby AT Desktop Case
Acer HX 08 ATX Full Tower Case
Acer (91.97020.A89)
Acer (91.97220.B07)
Acer CASE Mid-Tower ATX P4 350W FAN DUCT FOR 915, (4)5.25", (2)3.5", (1)3.5" 24PIN CONNECTOR USB kit COL... (9197120A51)
Acer (91.97020.A68)
Can you Help with these PC Cases problems?
Apple G5 Case with Power Supply (p/n...
Apple g4 digital audio Power...
Dead supply. Where can I get... Answer This...
Repair Service
Find PC Case Repairman Near You:
