Question about Zenith Z32X31D 32" TV
Zenith 32" NO audio
TV has no audio. I try using external speakers and nothing. What can the fix be?
    Problem Solver:
  • 25 Answers
It is likely the audio amplifier is defective.have your technician replace the audio amplifier IC.
Posted on May 18, 2008
I have a Zenith P60W26P 60" Plasma TV that the sound went out. Any ideas? and yes, I tried the mute
Check the audio settings and make sure that you did not set it to external speakers only.
Jan 14, 2015 | Zenith monitor P60W26P User Manual
Hook up sound bar to zenith plasma tv
If the sound bar has the red and white cable then yes you can use those. Make sure in your settings for the TV you have it set for an external audio source. Since you don't want to use the built in speakers. Probably best to get a tuner if using multiple speakers and a sub.
Dec 29, 2012 | Zenith Z60PV220 60-inch Plasma TV
Zenith inteq iqb50m90w has no sound, hooked up cable box with component cables
To be honest I do not really understand clearly your issue so I will pose a few questions that might clear things for me up:
1. No sound from internal speakers.
2. Speakers have be checked and are not open, disconnected or switched to external or variable audio out only.
3 A DVD or similar connected to a rear video and audio input has no sound.
4. The set had sound when hooked to the bose system.
Do I understand correctly or did I miss something?
If all the above is correct the set has a audio output problem (old trick is put ear directly to a speaker and see if anything, a buzz, faint sound or nothing at all.)
Dec 04, 2012 | Zenith IQB50M90W 50" Rear Projection...
How do i connect external speakers
Hi, Unfortunately it has no audio output jack / connector. But if you want to enabling audio output just tap it on internal speaker wires ( make it parallel or disconnect internal speaker and use your external speaker).
Regards, vote please, Jay
Jan 19, 2011 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
How can I hook up external speakers? I have
Go to your tv menu, and make sure that your fixed audio output is selected not variable. Variable will make not work, with the television volume is turn down. When you hook the speakers, make certain that it is on a fixed audio out, not variable, as well.
Oct 27, 2009 | Zenith C34W23 34" TV
How do i hook external speakers to sony bravia television
The proper way to do this would be to use the audio output from the TV, either analogue left and right or the optical port, and send it into an dedicated amplifier or AV receiver. You can then use the amplifier or receiver to power the external speakers. If you are using a dedicated amplifier with no volume control you will want to change the audio output setting on the TV to "variable out" as oppose to its current "fixed out"settings. You can find this in the TV menu, usually under the audio settings. This will allow you to use the current TV remote to adjust the audio volume coming out of the external speakers.
Aug 21, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
32" Ilo Tv
This particular unit has a basic problem with the control board.
You can find control boards on EBay, or through a local technician. Please refer to our online technician list for a professional near you.
Good luck :)
Jun 13, 2008 | iLO 3200 32 in. LCD Television
Variable audio out has no output
I turned off the internal speakers in the TV and the external speakers then worked.
Feb 25, 2008 | Zenith D52WLCD 52" Rear Projection...
Speakers
Tvs are wired differently these days. Your old Zenith for example probably had a selector switch that allowed you to change from internal or external speakers, bandpassing the audio from the internal amplifier to the audio out connectors. Your Sharp on the other hand may be controlled by customer menu to perform the same function as the external switch. Go into the menu and sub-menu of the audio and see if it gives you any choices for selecting internal or external speakers... If it doesn't it probably will not bandpass the already amplified signal, which means if you want to listen to your Tv on those external speakers you'll first have to pass the audio sample through an amplifier.
Hope this helps.
Bill
Nov 14, 2007 | Sharp 25N-M100 25" TV
Magnavox projection tv hookup to external speakers
The external (audio out) connectors are intended for use with an external amp, not direct speaker connection.
Sep 02, 2017 | Televison & Video
Televison & Video Logo
59 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
