Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool Refrigerator The water supply line leading into my refirgerator look dirty. I bought the kit and i'm trying to replace water line. ON the front I can't seem to figure out how to remove fitting that connects plastic tubing. I attache photo can any body help Thanks
  • 868 Answers
Ok you have to pull the collar back at the sametime and remove the line.To be sure send me a picture to archieferrarini@yahoo.com
Posted on May 21, 2008
Ice maker
The Ice maker requires a connection to a water supply. If you look behind the refrigerator you should see thewater fill valve connection. It is located on the right side on the bottom. A supply line kit can be purchased at a locat home improvement store like lowes or hope depot.
Jul 28, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Nasty tasting ice cubes
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Jul 13, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Refrigerator Water Hose
copper is best with compression fittings, just install an in line filter
Sep 29, 2009 | Refrigerators
My ice and water taste funny in my Whirlpool ED25PQ. How can I soleve this issue
You can install a filter in the incoming 1/4" line leading from the wall to the refrigerator. These can be purchased from Lowe's or Home Depot and come with installation instructions. Be sure to buy the whole new filter system not just a replacement cartridge.
If you have copper water line you will need a tubing cutter to cut the supply line for filter installation. If the line is plastic a sharp blade will do.
Good Luck
Sep 06, 2009 | Whirlpool Freezers
Water filter replacement
I have the same problem. I did change the filter located on the bottom front panel of the refrigerator, but the red light is still on and NO ice. I can't figure it out and I know if I call a tech, its a 300.00 bill. Frustrated.
Sep 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Broken ice maker in whirlpool side by side refrig model no.ed2ghgxmq00
1. Check freezer temp. Above 5 degrees? Icemaker will not start. 2. Make sure there is water coming to the refrigerator from the supply line. 3. Is the refrigerator clean underneath? Fan running? Dirty refer bottom can cause high freezer temps, see #1. Ideal freezer temp is -5. Icemaker and valve should be checked by a service tech.
Jun 26, 2008 | Whirlpool ED2FHSS Side by Side...
Water problem
if the lines are plastic then it has to do with your water supply line. is the supply a saddle type valve in your basement and is it connected to a copper pipe or a galvanized steel pipe?
Apr 30, 2007 | Whirlpool GS5SHAXN Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
101 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
