-   cd sticking / snaging only on turntable mode.-   apu h
Mar 25, 2009
-   MY TECHNICS SL-DZ1200 HAS A PROBLEM WHEN IN TURNTABLE MODE...SOUNDS LIKE A DRAG!! I REPLACED SENSOR SHEET CLEANED SENSOR & REPLACED OPTICAL BUT STILL HAS THE FAULT ...IT ALSO HAS ANOTHER FAULT WERE IT DISPLAYS TRACK ERROR INTERMITTANTLY WHEN PLAYING A MP3...
I had the same problem. Replacing the sensor is not gonna help. it is a focus problem. I had to fold a small piece of paper and put it under the sensor to raise it up alittle then you screw it in. The size of the paper you will have to figure out for yourself, but it will help u fix your problem
I had a similar issue with my Technics sensor, I just tried the paper solution, hoping its not so temporal but will last for a while as I do a lot of mobile events... Thanx
i was djing at a night club and there was a little bit of crown and coke spilled on the top of it. i...
(More)
i was djing at a night club and there was a little bit of crown and coke spilled on the top of it. i cleaned it off and it worked fine, i thought it was no big deal and then the next night when i started to warm up i noticed that it would play fine but the turntable has a lag on it when you move it like as if the top white part with the three holes in it to lock it when you recive it in shiping was sticking to the bottom part. as if it needed some wd-40. would cilicone spay help??
Hi, I've just bought a used Technics HD81 system and i'm running my tv through it, it worked perfect...
(More)
Hi, I've just bought a used Technics HD81 system and i'm running my tv through it, it worked perfect for around 30 mins and then just threw a wobbley. the system changed to CD on its own and then kept skipping through the cd's, flicking random selection on and off, same with repeat and randomly played songs without me touching anything, the system was then jammed on the CD selection (it wouldn't change to radio aux or tape) but i couldn't open the CD tray, no matter what button i hit it just kept switching the random play on and off- even if i push a buton on the tape deck. Have you any idea whats wrong with it please. Regards Brian
It will spin the circular bed that holds all 5 CDs, then randomly stop to begin a CD, but before it...
(More)
It will spin the circular bed that holds all 5 CDs, then randomly stop to begin a CD, but before it actually starts a track, it stops and again starts spinning the circular bed to repeat this entire process, never to play a track. It doesn't seem to matter which buttons I touch,the player has a mind of its own and eventually after many frustrating minutes will stop and begin playing an entire CD.
My Technics SL-PD8 5-disc player continuously makes a whirring sound and the tray will not open. I...
(More)
My Technics SL-PD8 5-disc player continuously makes a whirring sound and the tray will not open. I had a look inside and it appears to be something wrong with the disc-reading mechanism. Please help!
