Question about Toshiba Computers & Internet
Toshiba Satellite P25-S5092/ Computer will come on, but screen will not work. Wondering if it is most likely the LCD screen itself, the backlight or something else.
    Brigadier General:
  • 6,966 Answers
If you have deduced that indeed the Toshiba Satellite P25-S5092 will boot and therefore operational except no display on the screen, you can always verify by connecting an external monitor. You of course would need to press Fn + F? (the F key with the small monitor icon).
As to the LCD screen having no display, often this could either be the CCF lamps (cold cathode florescent) and/or the inverter that powers it. One way to verify this is by shining a flashlight obliquely to the screen and a portion of your desktop would show albeit very very dark. Often, it is the inverter that fails. In some instances it could even just be a cold solder, loose connection or capacitors that have dried up, leaky or blistering.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 18, 2008
Testimonial: "That is what I thought. Thanks"
My toshiba satellite a215-s7472 screen is very dim can hardly see anything what do I do too fix it I tried ajusting the light .
Primer:
An LCD screen does not produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED lights.
(Two present technologies being used)
The Toshiba Satellite A215-S7472 Notebook PC uses a CCFL.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average size is 2mm by 334mm. In inches that is;
Approximately a little thicker than 1/16th of an inch Thick, and a little over 13 inches Long)
A screen Inverter is used to convert the power (Electricity) from the laptop, for the Backlight, and LCD screen.
Point of all this?
90 PERCENT OF THE TIME the fault is a bad Inverter
http://www.irisvista.com/tech/laptops/toshiba-satellite-a215/disassemble-display-panel-1.htm
http://www.zkarlo.com/selected-zkarlo-part/inverter-board-p907.php
HOWEVER, the Backlight bulb is located inside the Screen Frame, of the LCD display assembly.
An LCD screen is composed of layers. These layers are held in a specific pattern, by the LCD screen frame.
This is a thin metal frame which surrounds the LCD screen layers, and has Philips head screws which hold the frame together.
NOTE*
The procedure is fairly intricate.
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
For additional questions please post in a Comment.
Regards,
joecoolvette
[ So far I have only seen listings for the LCD screen itself, and not a separate CCFL Backlight ]
Feb 01, 2012 | Toshiba Computers & Internet
The monitor on my Toshiba P25-S5093 does not have any display of any kind; all black. I have display using external monitor.
Does the display show anything before you enter windows? If yes, then press the key to transfer video back to your original screen once you enter windows. It should be the function key "Fn" + F5 - F8. looks for the icon which shows a monitor or says "CRT/LCD".
If it doesn't show anything before you enter windows I'm afraid your screen needs to be replaced. Good luck.
Mar 08, 2011 | Toshiba Satellite P25-S5093 Notebook
I recently installed windows seven and now it doesnt give me the option to connect to the internet via wifi,i also looked in device manager as it is not listed.
Hi, the problem here is that your pc was not designed for windows seven. You can try downloading the latest driver for your device, or you may need to use a plug in to usb, to get wifi. Also for windows 7 you will need a minimum of 2Gig of memory.
Aug 29, 2010 | Toshiba Satellite P25-S5092: P25-S5092...
Own a Toshiba P25-S5092. Will not power up. Goes
Power problems may do this, also if the CPU's heatsink has been loosen or detached, the CPU may me getting to hot and will self shutdown.
Aug 07, 2009 | Toshiba (K000006610) for Satellite P25...
Media Test Failure?
go in to the bios and change ur boot order so the harddrrive is before the network or lan
Nov 23, 2008 | Toshiba Satellite A40 Notebook
Toshiba Satellite P25-S5092-display problems
what you need to do is replace the backlight to solve the display prob and as far as the fan and being that old you should replace the fan
Oct 08, 2008 | Computers & Internet
Bluetooth, Driver
All the toshiba products are her >< just select you model and then the driver you want
Oct 04, 2008 | Toshiba (K000006610) for Satellite P25...
Toshiba satellite p25-s509
I think this is already a hardware problem, it could be your LCD or your systemboard, try connecting an external LCD or monitor thru the VGA -out & check if you have a display. If not, it might be your systemboard that's causing the problem & this may require service.
Hope this helps.
Jul 01, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite P25-S5263 monitor problem
It could be a driver problem perhaps. Does the post screen show at all or is there absolutely nothing?
Dec 29, 2007 | Toshiba Satellite P25-S5263 Notebook
Computers & Internet Logo
168 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
