GE 20.3 cu. ft. / 575 liter Upright Freezer FUF20DPRWH
Problem for GE 20.3 cu. ft. / 575 liter Upright Freezer FUF20DPRWH
Whirlpool FUF20DPARWH Freezer
By Jebuc on May 18, 2008
I have the freezer above and after about 1 1/2 yrs it started leaking water instead of defrosting properly. I found a large amount of ice on the bottom so even though it was a self defrosting freezer, I defrosted it the best I could. I noticed that where the heating coils are located seemed to be incased in solid ice. I am asssuming this is causing the freezer not to self defrost properly and leak the water. How do I go about getting rid of this ice since it is behind metal in the back of the freezer? Or do you think there is a different problem?
Best Solution
posted on Jun 30, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Was the door left open for a long period of time.? Sometimes this causes so much ice that it re freezes and can't clear the drain. The only solution is to unplug and let sit with doors open for at least 24 hours. to get all the ice off the coils. Then use a pipe cleaner on the drain then use a turkey baster to force water through. then a mild bleach solution. Check the door gaskets if they are ripped or loose or the door warped and not sealing tight this will also cause this problem. If this still doesn' t solve the problem it is probably a defrost problem Usually the timer or defrost thermostat.
Popular Solutions for GE 20.3 cu. ft. / 575 liter
Questions and Unsolved Problems for GE 20.3 cu. ft. / 575 liter
Do you recommend GE 20.3 cu. ft. / 575 liter Upright Freezer FUF20DPRWH?
Answer
Answer
Freezer is running and keeping food cold but not frozen. Water leaking from bottom
Answer
I just de-frosted my frost-free freezer5 months ago and it is building up frost on the top shelf... (More)
Answer
If the compressor on our freezer is bad, will it just suddenly stop or are there warning signs?
Answer
The alarm went off on it a couple days ago and we started watching it and I turned it where it... (More)
Describe your Freezers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Freezer Experts
Top Refrigerator Repairmen
in , MD
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
