Question about Goodman GMS90703BXA Heater
Ever hear of this odd problem?
I have a GMP075-03, was freezing up because it was low on freon. Turned unit off and called for service. After freon, unit does not freeze up, but we have a new problem that I noticed when it was freezing up as well. You turn on the air and about 5 minutes, sometimes 3, sometimes 10 after you turn on the air, (which works fine) the draft induction fan comes on (the fan that purges the system before the heat comes on.) This fan runs for about a minute and then you hear it shut off, and then start back up, and continues this cycle until I manually turn off furnace power downstairs. I put on a new thermostat today and that did no good. When it does this in air mode, the ignitor never comes on or anything like that, just the draft induction motor. Any help would be appreciated. My wife has a rare form of cancer and I'm just trying to save any money I can. I'm very mechanically inclined...there are just so many sensors I wouldn't know where to start guessing. Thank You In Advance!
  • 1,420 Answers
Sounds like the main circuit board. Get the freon level up to spec and if you can live for now with the inducer fan issue, let it ride. It will fail at some point.
Posted on Jun 03, 2008
Whirlpool freezer cool air but not freezing?
Check the seal first. Then check the freon. If it's R-12, you can go to the auto parts house. They have a bottle with a hose to add freon. You put it in on the "suction" low side with the unit running. you can tell when it has enough by feeling the low line be cold and teh high pressure line is warm to hot
Jun 06, 2014 | Kenmore 14.1 cu. ft. / 399 liter Upright...
I have a Goodman home A/C unit and the copper line coming into the house freezes up. The unit continues to run with no cold air. I was told it is either dirty or low on Freon. Are they correct? If it is...
Hello
If you have ice on bigger copper line and no cooling then the unit is low in freon.
As far as cleaning it,you should clean the outside condenser in the spring.Use some simple green and a hose to clean the coils,this will make it better for the heat to transfer to the outside and cut your costs of running the unit down.
No you can not do freon yourself you need to be cfc certified now,which means you can not buy freon.Best to have a service person come out.
Apr 04, 2011 | Heating & Cooling
Unit is fully charged but suction line freezes
hi there,
this sympton persist in over charging of freon it is call super charge,exessive charging of freon resulted to freeze your suction line,this is bad for the cycling process.to reduces freon charging purge out exessive freon on low side charging port.make sure service charge pressure gauge valve was installed.to determine the exact operating pressure. have a nice day fix my rate,thanks a lot.
May 14, 2010 | Heating & Cooling
I have an Amana fridge model 85381 that kinda
could be low on freon call a repair service to test it .
Oct 26, 2017 | Amana Refrigerators
Air not circulating through vents
is the unit running outside? did you check the breaker? Ruud units often times will have a reset bitton on the outside unit to the left of where the freon lines connect. It is a high pressure switch if it comes on when reset make sure the coil is clean and the fan runs(outside)
Sep 20, 2009 | Ruud UBHC Air Conditioner
Fujitsu ASU12C1 is freezing up
unit is freezing up because it either has too much freon or not enough. the pressure should be checked on both the low and high sides and corrected.
Jun 13, 2009 | EMI EHW 18000 Air Conditioner
Ac unit freezing up
Either the coil is clogged, the fan is slow, or the freon is low... A solved rating is great motivation to continue giving priceless advise........
Oct 03, 2007 | Samsung AW0603B Air Conditioner
Goodman GMS90703BXA Heater Logo
67 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
