Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Error code my printer displays H4 error code when i power it
Xeroxpe16 problem cru fuse error on display what is this
Posted on May 23, 2008
    President:
  • 2,072 Answers
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly
Posted on May 18, 2008
My Printer is displaying an H4 error
The error code H4 means that you have a problem with the fixing unit. It could one of the item's > The thirmistor or thermal fuse or the fixing heater lamp
Oct 05, 2012 | Sharp Office Equipment & Supplies
H4 Displays
H4 indicates "low temperature", possibly caused by a failure of the heater lamp or fuser. Sometimes this error is shown without an actual damage when the power cord is pulled without shutting down the copier first.
To cancel the error code, press [CLEAR], [AUTO], [CLEAR], [AUTO] in rapid succession. The display should go blank. Next, select 14 (clear low temperature code), press [START]. Finally, switch off and on the machine.
If there was no actual damage (i.e. power cord pulled), the machine should be OK again. If the error persists, immediately or after short time of operation, you will need to contact Sharp technical service for repair.
Jan 10, 2011 | Sharp AR-5316 Advanced Digital Imager...
The copier displays H4 What is the solution?
Jan 09, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL-800 is blinking H and 4 what could be the problem?
the error code H4, means that an abnormal temperature was detected in the fusing section (the hot roller was not working properly during the initialisation of the printer), to solve the problem;
  1. unplug the printer from the power source
  2. wait for 10 mn
  3. plug the printer again to the power source
  4. switch on the printer
if the error H4 still displayed, you need change the fixing unit, that must be doing by a qualified technician,
Dec 14, 2010 | Sharp AL 800 Copier
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
Xerox pro 215, error H4 please help
H4 is a fuser error....not getting up to temperature.
If this doesn't bring it back to operations then the fuser lamp needs to be replaced.
Jan 17, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Please Help
H4 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
H4 error code
H4 is a Fuser Unit heating problem.
This reset is for another model sharp, see if it will work for you.
Press "Clear", "Auto Exposuer", "Clear", "Auto Exposure", the display will go dead... then press "14" (Like your going to make 14 copies), then press "Start".
Hope this works.
Good luck,
Mac
Feb 10, 2008 | Sharp AL-1551CS Printer
Cant get rid of blinking error message, nothing works
The [H4-00] system error popped up when the power went out of the house. I called Sharp tech support (1-630-378-3590) and was talking to their tech support in less than a minute.
The FIX? Just press the following keystrokes:
# * C * This will clear the display error, now press…14, then press the green button twice. This should let your printer start to warm up and you have fixed your problem.
Dec 20, 2007 | Office Equipment & Supplies
Xerox printer xd100
H4 is a power failure code. To reset the error please press in the following order: CLR - AUTO - CLR - AUTO (this puts the unit in tech mode). Enter 14 (as if asking for 14 copies) Press "PRINT" Your unit should reset itself and start working.
Sep 24, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
356 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
