Question about LG WM-2277HW Front Load Washer
LG WD-1290RD FRONT LOAD WASHER/DRYER chimes with blank front panel
I have had a LG WD-1290RD FRONT LOAD WASHER/DRYER for just under 3 and went to use it one evening when none of the controls would work, I turned it off and back on and the chime would not come on, turned it off again and waited for 30 sec or more and turned on, chimes worked but no response from power button at the front, the child lock however does work I opened it up to look for any signs of burnt out parts but cannot see any. Checked the hoses at the back to see if they where clogged but looked fine after closer inspection. cleaned out the detergent bowl and checked hoses. Cleaned out the botton filter not much there.
what could it be?
Turned out to be the control board and the transformer - an expensive fix!
Posted on May 27, 2008
  • 489 Answers
Unplug the unit to reset the computer.  Wait 5 minutes.  If the problem still occurs, you will need to have the control board replaced.
Posted on May 26, 2008
Washing machine
I see a little confusion here...there is LG WD-1280FHD which is the MODEL number, WD= washer-dryer, LG=Life's (not so) Good. The "F" is for Front Load... HD for dryer Heated Dryer. The numbers correlate to date and assembly plant location. IDK this other number your showing is a Part Number
Mar 15, 2014 | LG WD-1280FHD Front Load Washer
Water will not enter the machine on the cold water setting on my lg priviledge washer dryer combo model wd-3243rhd.i here a humming noise but know water.
I have a similar problem with my LG WD-3245RHD. I had a repairman come out to look at it and he said I needed a new circuit/control board. I have not been able to locate this replacement part to date. RepairClinic.com has one listed, but it is not in stock.
Nov 03, 2010 | LG WD-3243RHD Front Load Washer / Dryer
My washer/dryer is leaking water as the drum is filling. Does not matter if it is hot, cold etc. I have already cleaned the filter..... HElp!!!!!
your tub fill tube hose that goes from the bottom of the wash tub to the load size control on the control panel may have a hole in it, its plastic
Aug 24, 2009 | LG WD-3274RHD Front Load Washer / Dryer
Would like a owners manual for my WD-1290RD can't seem to find one on the net anywhere.
Here's a link to a site with your manual, it's free. If you need a different manual for a different country, just use the search bar on the site to locate one.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WD-1290RD-_E
Hope this helps, and best regards!
Jul 31, 2009 | LG Washing Machines
LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Feb 10, 2009 | LG WM2432H Front Load Washing Machine
LG privilege WD-3243RHD User Manual
Find out where in your area it was sold and phone or ask salesman for Manuel or instructions they will be glad to help.
Jan 22, 2009 | LG WD-3243RHD Front Load Washer / Dryer
LG WD12311RD FRONT LOADING WASHER DRYER.
Those bolts have to be removed prior to use or you will damage the machine.  The drying issue has to be addressed by a qualified LG technician.
Mar 21, 2008 | LG WD-14124RD Front Load Washer / Dryer
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Feb 11, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG WM-2277HW Front Load Washer Logo
1,713 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
