Question about Canon Office Equipment & Supplies
Leaving a Pixma MP180 un-used for 3 months is it advisable to remove the ink cartrigdes and cover them with selotape to seal the ink in place.
    President:
  • 1,944 Answers
I would recommend doing as you stated. This would prevent the ink from drying up due to unuse.
Posted on May 18, 2008
Canon mp180 ink absorber full
This mayclear the ink absorber problem.There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
May 31, 2012 | Canon PIXMA MP180 All-In-One InkJet...
I'm getting a 5100 "check printer" error on my
Reseat (remove / reinstall) the ink cartridges if an error appears. Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
    Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
Installing ink cartridges:
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  2. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  3. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  4. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  5. Fold the scanning unit support and close the scanning unit (printer cover).
  6. Wait until the preparatory operation is complete; it takes about one to two minutes.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 23, 2010 | Canon PIXMA MP180 All-In-One InkJet...
INk LOW DISPLAY DOESNT RESET AFTER RENEWAL
Dear Sir,
Here is the Solution,
By using mp tool software we can resett ink levels,mptool is the popularness software to reset printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460. Excess of software that is the program measure of small and amenity of usage. Ability of the software that is to reset level black and color cartridge at canon pixma mp series. And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
Download Mp tool
this solution deffinately solves your problem
Aug 27, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon MP180
That error code is described below:
Error Code Error indication Error condition.
5B00 Waste ink full H/W fail Replace printer.
And i would like you to refer to www.feedroller.com/Store/Service%20Manual/S100sm.pdf
Thos document has all the error codes and what needs to be done for that.
Hope my info is useful,
Thanx for using fixya.
Sep 26, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Ink cartrigde
Did you remove the protective blue tape from the cartridge bottom, if please clean the cartridge Take a warm, damp paper towel or napkin and gently clean the bottom of the car where ink comes repeat the same process with dry paper towel and try to print , if you still have the problem you can contact lexmark and get the cart replaced with a new one as the cart comes with 6 months warranty.......
Jun 30, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon mp145
ARE U USING REFILLED CARTRIGES ? IF "YES" ,CONTINUE USING UNTIL COLOR PICS COME OUT UN NATURALLLY LIGHT SHADES OF PURPLE.
(U CANNOT RESET INK LEVELS)
May 31, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Canon pixma mp180/mp160
a friend have me these printer with out the cd,,software,,somebody tell help me please
Feb 21, 2008 | Canon PIXMA MP180 All-In-One InkJet...
RECOGNITION OF GENUINE CANON INK CARTRIDGE
I posted the original problem. Although the cartridge was genuine I had taken it out and reinserted it as I wasn't sure I had loaded it correctly the first time. Advice from my local retailer was that this was a mistake. Canon PIXMA printers no longer recognise a cartridge once it has been removed. Solution was another new cartridge which I shan't remove until it's empty. When this second cartidge is empty I shall try the first cartridge again as it is still full and unused. It has yet to print anything! Why Canon's helpdesk couldn't help is a mystery. I conclude that Canon's printer management systems are unfriendly to users. They are friendly only to Canon. I hope my experience will help others especially those considering buying a Canon printer. dudbob
Jan 22, 2007 | Canon PIXMA iP1600 Printer
26 people viewed this question
old marine
old marine
