Question about Sony KP-57WS510 57" Rear Projection HDTV
RED SHADOW AROUND IMAGES of SONY KP-57WS510 RPCRT
My SONY KP-57WS510 RP TV has developed a red and blue shadows around the images. I love my this TV. I tried to adjust the convergence per the manual, but the red crosses does not move even move a micro millimeter. I have used the toggle button to have the red box around the cross to move. It does not move at all. Any kind of help will be highly appreciated.
Thank you in anticipation
  • RajSony May 18, 2008
    Thank you for your solutions to my problem of red shadow. How many ICs I need to replace. I was about to order one but then thought I rather confirm with you the no. of ICs I should order. Please advise.
    Like you suggested I should order 6 of 4.7 ohm x1/2 watt resistors too but how I would know that they are burned too. Please help.
    Thank you
    Regards
    Raj Ahuja
    targetimp@aol.com
  • Spiderman3 Jun 02, 2008
    Check the following url about the specs of stk392-560. It said "
    Use the STK392-570 to repalce the STK392-560". Should I have to buy STK392-570 instead of STK392-560?
    http://www.techlore.com/forum/thread/226...
  • Sony Master
  • 8,617 Answers
Your set uses two STK392-560 convergence ICs they are attached to a large heat sink on the D board. You can save your self about 400 for a twenty minute repair by getting new ICs at the following link as trhey provide free instalation instructions with pics so you can do the job yourself. It only requires basic soldering skills I would order about six 4.7ohm 1/2 watt resistors as well just in case you need them asusually sonys' will burn one or two of the 4.7ohm convergence resistors when the ICs fail. Heres the link
http://servicemanuals.vstore.ca/
Posted on May 18, 2008
  • Sonny Berry
    Sonny Berry May 18, 2008
    you will need two of the STK392-560 ICs. As far as the resistors they will often show up as discolored in the middle, But if not its easiest to lift one side of the resistor from circuit and check them with an ohms meter if theyre bad they wont register on the meter. If you dont have a meter Radio shack has them cheap as does the site that I directed you to has the ohm meters as well.
    Plus they will help you through the proveedure to check resistors and even tell you which resistor numbers are likely to be the ones open
I HV A SONY PROJECTION TV. WHEN I SWITCH IT ON IT GETS OFF AUTOMATICALLY AFTER FRACTION OF A SECOND. PLS SUGGEST SOME REPAIR MEASURES OR AT LEAST GIV ME A SONY SERVICE TEL NO. IN THANE
Posted on Jan 07, 2011
    Scholar:
  • 131 Answers
The problem is your convergence ics there are two. cost of part is 30.00 you would need a tv repair shop to fix . The cost is around 300.00. total. call around and get quotes fom service centers. T his is a common problem every 3 to 5 years so if you where going to fix it would last 2 to 3 years,
thanks doctor video
Sony KP-57WS510 Red Hue to screen.
Misaligned grey scale adjustment. Do a white balance adjustment, after entering its service mode. Contact the authorized service center of any experienced service technician. http://elektrotricks.blogspot.com/
http://electrotechnician.blogspot.com/
http://homenol.blogspot.com/
Please visit these sites to get some details.
Jun 15, 2017 | Sony KP-57WS510 57" Rear Projection HDTV
Sony rear projection tv shadow images around people red and green blue and purple
I think your TV has beam convergence problem. Depending on the model there may be user adjustments on the TV to align the beams on to the same spot as close as possible so that color shadows are minimized. Strong magnetic fields such as nearby unshielded speakers can also cause this problem. If that is the case, moving such magnetic field sources away may be the only solution.
Feb 25, 2011 | Sony Televison & Video
Hi, I have a Sony KP-57WS510 57 in. Rear
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 25, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Tripe image, blue, red and green color on image, not focus
you will need to replace the two STK392-560 ICs and also check the 4.7 ohm 1/2 watt resistors and the six 3.5 amp pico fuses.
May 05, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
Image on tv casts a red shadow.
TRY THE MAGIC FOCUS BUTTON. IF THIS DOES NOT CORRECT THE PROBLEM YOU WILL NEED A SERVICER TO GO IN AND REPAIR CONNECTIONS OR REPLACE THE CONVERGENCE IC'S AND OR RESISTORS. AND READJUST CONVERGENCE IN THE SERVICE MODE.
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
Red shadows around images on screen, setting convergence doesn't help
HELLO. it not in adjusting the len's it's in the convergance board. the IC'S ON THE BOARD NEED TO BE REPLACED."GOOD LUCK"
Jul 25, 2008 | Akai PTH5498 54" Rear Projection...
Red shadows and mild distortion
Hi, relasmith did you ever fix your tv kp-57ws510
thank you
Apr 03, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Sony KP-57WS510 Convergence issue?
Replace convergence IC's....STK392-560 X 2 + check pico
fuses under IC heatsinks.....................T.
Nov 12, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-57WS510 57" Rear Projection HDTV Logo
493 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
