Question about Jeep Liberty Limited XT Urban Earth Jogger
Tyres Where is a Jeep liberty Limited XT repairer in my area, I live in Hoppers Crossing, Victoria. The inner tube needs replacing.
You may want to try Kolcraft.com and look up a replacement wheel based on your model number. Otherwise, try a bike shop in your area and see if they have a temporary tire replacement until your order has been processed. Kolcraft also has a number you may call to order parts by phone.
Posted on Feb 21, 2009
I need to replace one of the back tire tubes & trying to find out where to get one for my 2005 jeep liberty stroller.
It looks like yours has the same wheels as mine which are 12.5 x 1.75/2.25 inch. I went to my local bike shop and bought new tubes for all 3 tires. You might even be able to find them at Toys R Us or Walmart or Target type stores. Hope that helps.
Tim
Mar 18, 2012 | Kolcraft Jeep Liberty Limited Urban...
The tyre keeps going flat. The valve on the inner tube was replaced and the tyre pumped up, but by the time I got the tyre home it had depflated again. There was a worn area on the inner tube and there...
Not a guru on Bertini but most strollers with pneumatic tires use standard tyres and tubes as used on kiddy bikes. I get tyres for Bugaboo's at my local K Mart. The size should be on the side wall of the tyre.
Apr 23, 2011 | Baby Gear
A spoke on the rear wheel has snapped off how can I repair it?
Simply buy a replacement spoke. Unscrew the dustcap on the tyre valve and deflate the tyres inner tube. Remove tyre using tyre levers(as you do to repair a puncture). Next remove the inner tube to reveal the spoke tensioners. undo the tension nut and allow the broken spoke to fall out, feed the other part of the broken spoke out of the hub. feed the replacement spoke through the hub and into the hole on the wheel rim. Now screw on the tensioning nut to the spoke.Tighten up to the same tension as the other spokes. replace inner tube and tyre, then reinflate. Viola!
Jan 30, 2011 | Cycling
How to replace the whip antenna on a 02 Jeep Liberty Limited
The antenna part unscrews from the fender mount and can be replaced easily. The mount and wire needs to be fed through the fender and firewall, most times making it necessary to remove or partially remove the inner fender liner for access. Not difficult but a pain in the **** to do.
Oct 13, 2010 | 2002 Jeep Liberty
Back wheels keep deflating
hi, the chances are you have a puncture os something sharp sticking into the inner tube inside the tyre, what you need to do is buy a puncture repair kit then using the repair kit you take the tyre off the wheel then take the inner tube out.
now blow the inner tube up and place it in bowl of water and you should see bubbles coming off the inner tube, mark this with pen when dry so you know where the whole is, now use the puncture kit and place a patch over the whole, you can buy glue type patches or stick on patches without glue, you peel the back off the patch and put glue on or stick it over the whole if its a stick on patch and not glue.
then whilst this dry run your fingers around the inside of the tyre and check for any thorns or something sharp sticking in the tyre if you feel anything remove it and you should be ok, then when glue dry put the inner tube back in tyre and fit the tyre back on wheel now when you pump it up it shouldnt go back down unless you get another puncture.
if you are unsure what you are doing then taking your stroller into any bike shop and ask them to repair the punctures for you and they will do this for you whilst you wait.
Jul 10, 2010 | Quinny Buzz Three Wheel Stroller
My quinny rear wheel keeps losing air, ive replaced inner tube but it keeps going flat
Hi it sounds like you have something stuck in th tyre itself that is punturing the new inner tube, take them out & feel inside the tyre if there is anything sharp there remove it. Then you can repair the tubes.
May 30, 2010 | Quinny Baby Gear
How do i fix a flat rear tire on a honda crf 150 f
hi there you need to remove the rear wheel an then remove tyre fom one side of the rim to be able to pull the inner tube out pretty much the same as you would with a bicycle tyre and wheel and either repair the hole if repairable or simply replace the inner tube and refit tyre and wheel hope this helps you
Dec 19, 2009 | 2005 Honda CRF 150 F
My jeep jogging stroller has a flat. Do I need to
Replacement tube may be more beneficial even though the fix/patch may be cheaper. If you live in an area that have varying climate, the patch along with the repaired tube can expand and contract and may cause small leak if not repaired properly.
Otherwise I would get the right size tube, most jogging strollers are either 12" or 16" tube inside and can be bought from your local bicycle store. With that, you'll need bicycle tire levers which can also be bought at the bike shop. Just about any type of tire levers will do. Of course I'm sure your bike shop can do this for you to possibly for free with a purchase of replacement tube!
Oct 27, 2009 | Jeep Liberty Limited XT Urban Earth Jogger
Jeep stroller wheels
yes u cxan order a new one go to any stroller shop or outlet they have them there or can help you
Sep 03, 2008 | Jeep Liberty Limited XT Urban Earth Jogger
Intertubes
You should be able to find a tube at Wal-Mart to fit your tire. We have a Jeep Stroller and Wal-Mart had the right tube.
May 17, 2008 | Jeep Liberty Limited Urban Terrain...
Jeep Liberty Limited XT Urban Earth Jogger Logo
134 people viewed this question
Top Jeep Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Jeep Baby Gear Expert? Answer questions, earn points and help others
