Question about Hotpoint HSS25GFP Side by Side Refrigerator
Ice dispenser damper door does not open
The Ice dispenser damper door does not open. If you open it manualy everything works OK.
  • Doorman2 May 18, 2008
    Make & Model is Hotpoint HSS25gfpc ww
    How do I get into the dispenser assembly to check the solenoid? I know how to do the electricaal testing but I don't want to damage anything as I take it apart. Make & Model is Hotpoint HSS25gfpc ww
    Sergeant:
    Champion:
  • 304 Answers
Defrost and remove the frost that accumulates on the roof and sides of the freezer. If it's more than 1⁄4-inch (6 mm) thick, think about switching to a no-frost freezer. Frost buildup increases the amount of energy needed to keep the motor running. Throw out the ice: The chunks at the bottom of the tray may have been resting there for years. Clean out the tray with warm soapy water, fill and return it to the freezer. Sweep through your fridge once a week. Throw out any leftovers that won't be eaten, get rid of perishables that are past their prime and wipe down any spills.
Posted on May 18, 2008
    Brigadier General:
  • 6,966 Answers
Initially, try do a manual cleaning of the door and the actuator (solenoid). The door might have some blockage of some sort at the swivel point or the solenoid piston/slider got ****.
It is also possible to have a defective ice dispenser damper door opener. The door is engaged by a solenoid. Although in some instances, the damper door has been known to be likewise defective. Both are relatively easy to replace and are not that expensive.
Should you venture to perform a DIY, parts are available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role May 19, 2008
    Hi again,
    Perhaps these documents would be of more detailed information. Some of the illustrations here and/or here might be of further information.
    Brigadier General:
  • 3,614 Answers
What model/maker your icemaker there..?
thank you
LG Freezer ice maker makes ice but wont dispense
There is a mechanical flap (trap door) that should open to allow ice that is being pushed by the auger in the bottom of the bin to fall out. Possibly the solenoid that opens the door does not work, or you just have an obstruction (piece of ice) preventing the door from opening far enough to allow the ice to pass through. Here is some helpful information and instructions.
Mar 19, 2014 | LG LSC23924ST Refrigeration : Refrigerator...
Damper in vent door opening and closing continuously
the vent damper opens and closes depending on the temperature
inside the fridge. You might try to change the temperature settings in the fridge and see if that helps
Mar 10, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
My whirlpool s21w2d freezer is working ok, but refrigerator is not cool
The place to start is in the freezer..Is there ice on the back freezer panel? the freezer cools the refrig section and if froze over..the air will not flow to ff section. we have to make sure the coil is not frosted over...this is the most likely fault...the damper that lets air into the ff section can also be froze and not openning..if you have digital readout you can be sure you have electric damper...See if you feel air flow out of vent in top left corner of ff section. if no air or very little.. look for the freezer coil being froze or the damper stuck shut...of coarse, the freezer fan may not be running or coming up to speed...I use a skewer or something like that to slide it thru the damper and wiggle it around until it slips in further..this opens the damper and lets air in if its bad of coarse...the fix would be..leave it open with skewer until you buy a new damper...if froze up in freezer..defrost with hair dryer and find what caused freeze up situation. This is where you need a little more experience working with multi-meters. UNPLUG and check reading to heater and to defrost thermostat..if ok, the defrost timer is at fault.
Jan 24, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
MODEL FFS26ZRG THE ICE CRUSHER CHURUSHES THE ICE
there might be something in between the door and the ice crusher. If you could check what it is, would be good otherwise call in a repairman to work on this problem.
Jun 11, 2010 | Frigidaire FRS3R5EMB Side by Side...
Water and ice maker not working line frozen everything frozen even when you turn it down is it the termostat or what
It sounds like your ICE Dispenser door is stuck partway open. Defrost the access door, ice bucket and crusher then check the Ice Dispenser door to be sure it fully closes, otherwise cold air will constantly drift out and freeze the whole mechanism.
Mar 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser door not closing fully and ice is forming in the opening. How do I remove the panel to replace the dispenser door mechanism?
The hood,Canopy has to be snapped apart at the bottom, then slid upwards to disengage the retainer tongues at the top, of which there are three. Then I was able to see that the connecting rod on the damper which causes the ice dispenser door to close slowly, was bent and about to break and interfering with the dispenser door flap not to close fully.
Aug 24, 2009 | Refrigerators
GE Profile Arctica Side by Side with ice maker and water in door
Plz provide me with the full name and model of your appliance for there is a lot of diferent makes and sizes,plz reply asap so we can sort this problem out for you.
Thanks...
Wouter.
Sep 10, 2008 | Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
103 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
