Back to:
Intel Motherboard
Bios problem (by 2 users)
posted by thomaschino1 on May 18, 2008
my bios settings was set to default by mistake.after that my computer cannot detect any IDE devices.how can i solve that problem.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 07, 2008
Can't detect my sata hdd
Solution #1
posted on May 18, 2008
Not Rated (0)
wiparu
Rank:Wiz Wiz
Rating: 82%, 40 votes
1. log in to the BIOS first & press F9 , it configure with default setting, this command press in all the bios configuration.
2 check with the idu bus,& any pin is broken,R change the IDU bus.
3check in main broad change the idu slot.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on bios problem:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Ekse
Rank:Guru Guru
Rating: 86%, 1495 votes
you need to go into bios and set the ide drives correctly.
Thank You!
Can you Help with these Motherboards problems?
Intel Motherboard
please i need the driver for this hardware "via cbp...
Intel Motherboard
hi guys n iwant to know that which motherboard should i...
Intel Motherboard
Dear sir, This is murthy from india and i am looking for...
Intel Motherboard
Witam Mam pytanie . Po właczeniu komputera...
Intel Motherboard
je peut pas installer apres le formatage les elements...
Loading problems.
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
