Canon i960 worked perfect until one day I turned it on and got 5 short amber & one long green light blinking at me with a little message in the print box saying
"Operator error.
Press printer's RESUME button.
If this doesn't clear the error, cancel printing and turn the printer off and then back on."
You can try reseating the print head.
Click on Service and Support, then type in 5 flashing lights. Click on the first result, then the first on the solutions list.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/i_series/i960_series#ServiceAndSupport
1. Hold down RESUME and then hold down POWER 2. Release RESUME 3. Press RESUME twice, then release POWER 4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute: presses - light color - function
Number of presses - light color - function 0 presses - green - Test print (or exit service mode on i960) 1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850) 2 presses - green - EEPROM initialize 3 presses - orange - Reset waste ink counter
Probably your waste ink counter. Should be cleaned or replaced before
resetting but usually you can get away with resetting once. 1. Start with printer OFF 2. Hold down RESUME and then hold down POWER 3. Release RESUME 4. press RESUME twice, then release POWER 5. let green light blink until printhead has finished moving. 6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960) 1 press - orange light - EEPROM info print 2 presses - green light - EEPROM initialise 3 presses - orange light - reset waste ink counter.
Probably your waste ink counter should be cleaned or replaced before resetting but usually you can get away with resetting once. 1. Start with printer OFF 2. Hold down RESUME and then hold down POWER 3. Release RESUME 4. press RESUME twice, then release POWER 5. let green light blink until printhead has finished moving. 6. Select functions below with RESUME, execute with POWER
hi, CANON PIXMA MP160 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
How long has it been since you printer prior to the other day ? If you do not use your printer for some time, the ink will dry out even if it's a new cartridge.
Canon i850, i950, S600 Start with the printer OFF 1. Hold down RESUME and then hold down POWER 2. release RESUME 3. press RESUME twice, then release POWER 4. Let green light blink until printer is done futzing Select function with RESUME press POWER to execute: presses - light color - function Number of presses - light color - function 0presses - green - Test print (or exit service mode on i960) 1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960) 2presses - green - EEPROM initialize 3presses - orange - Reset waste ink counter
If I could be of furtheme know. If this helps or solves the issue, please rate it. Thanks, Joe
1. Start with the printer OFF 2. Hold down RESUME and then hold down POWER 3. release RESUME 4. press RESUME twice, then release POWER 5. Let green light blink until printer is done moving print head. 6. Select functions below with RESUME press POWER to execute:
Number of presses - light color - function 0 presses - green - Test print (or exit service mode on i960) 1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960) 2 presses - green - EEPROM initialize 3 presses - orange - Reset waste ink counter
Try the below procedures maybe the error of your printer is the waste ink counter.
Canon i550, i560, i850, i950, i960 (May work with i860, i865) 1. Start with the printer OFF 2. Hold down RESUME and then hold down POWER 3. release RESUME 4. press RESUME twice, then release POWER 5. Let green light blink until printer is done moving print head. 6. Select functions below with RESUME press POWER to execute:
