Question about Frigidaire FRT18B4A Top Freezer Refrigerator
Defrost problem water leaks into the frig from the freezer when it goes into auto defrost
  • jag0159 May 30, 2008
    I have the Frigidaire Refrigerator model # FRT21Il4FW2, and I also have the water leaking into the bottom of the frig, collecting under the crispers. It seems that the water will drain from the freezer to the collection pan unit, with the light, etc. It seems to have a drainage block in the line itself. I took a can of compressed air, and tried to blow out the debris, but to no success. It seems the drain line is not accessible to service...I tried to convince a clothes hanger down there...but it seems to get stuck approx 8-10 inches in to the line. Any suggestions??
    John
    4109634792
  • 828 Answers
Drain line in the back of the refrigerator is restricted in some way . it may be plugged near the drain collecting pan air trap or loop.
Posted on May 18, 2008
Every Couple of Days water leaks out from under the freezer. I bought it from Home Depot about 2 months ago. What do I do now?
every 8 hours of cooling ( compressor run time ) which may be every cople of days the frig has a auto defrost . your unit may use a a d control so it may do it an any time it decides to defrost . when defrosting the water goes through a drain and under the frig to a holding pan . if pan is cracked or if drain hose is not in the pan it would leak .. it should be under warranty so i would call maytag and im shure they will correct the problem .. mope this helps mm ..majic **** ...
Oct 22, 2010 | Maytag MFD2560HES Bottom Freezer French...
The inside of freezer is leaking from back wall - there is no ice maker. water that leaks is freezing and taking up space. what can be causing this
the drain line is clogged causing the ice build up .the frig has to defrost every 6 to 8 hours so every time it defrosts is when it will leak ..you will have to defrost the frig manually ..turn it off. open the doors. let it defrost. remove the thick ice on the bottom ..after its defrosted take the bottom an back panel off.. un plug frig first !! drainline is in the back in the middle of the freezer. unclogg it hot water or shop vac be carefull good luck!! drain line should go to a pan under the frig, in the back make sure it drains before putting back together
Aug 21, 2010 | Estate TT18TKXKQ Top Freezer Refrigerator
Side by side frig/freezer. Freezer auto defrost
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Frig is leaking water down the back wall, about 1/2 cup in 24 hr
You probably have a clogged defrost drain. When the unit goes into defrost, the melt water is intended to go down a tube from your freezer down to the bottom to a pan. if the path from the freezer gets clogged, the water will seek its own level, and drip into the refrigerator. the short quick temporary fix is to unplug the unit and open both doors, blow fan for 24 hours. You will eventually need to have this serviced by an expert refrigerator repair service, it shouldnt cost more than $150, but if you attempt on your own, you could cause expensive damage, possibly forcing yourself to buy a new refrigerator.
Apr 09, 2010 | Amana ATB1935HR Top Freezer Refrigerator
Finding a puddle of water each morning under the left front of frig--does not leak during the day?
YOUR DRAIN IS CLOGED.LOOK AT THE BOTOM BACK PORTION OF YOUR FREEZER. (INSIDE) WHEN YOUR FREEZER GOES INTO DEFROST THE WATER HAS TO GO SOMEWHERE. IF THE DRAIN IS CLOGGED IT WILL FLOW OUT THE FREEZER DOOR.
Mar 16, 2010 | Refrigerators
Our upright frigidaire freezer leaks water......not all the time...just every now and then
turn off power to frig or unplug and let it defrost, if water drips inside and no water drips in the pan on top of the compressor after defrost then the drain line that goes to the pan is clogged. also sometimes the pan itself develops a leak, but that will be self evident. If this resolves problem for a period of time and problem returns then probably defrost timer
Mar 09, 2010 | Frigidaire Freezers
Frigidaire frig ice maker line leak
Could you put a small circular hose clamp on the hose line?
Apr 23, 2017 | Refrigerators
Kenmore 25.8 side by side with water freezing in the bottom of th
It sounds like the freezer drain is plugged up. When the frig goes into the defrost stage it melts the frost biuldup on the evaporator and the melted frost goes down a drain that is behind the evaopator cover. When this dran is plugged the water has no place to go and over several defrost cyles will actually run into the bottom of the freezer section. When the defrost cycle is over and the frig starts cooling again, the water freezes in the bottom of the freezer.
Nov 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Frig side is not cooling.
Check if there is frost on the back wall of the freezer, if so it is not defrosting. Many GE fridges need a new defrost heater every couple of years. If it's not defrosting, you can get by for a while by unplugging the fridge and leaving the freezer door open for 24 hrs, then plugging back in.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Defrost Problem
there is a drain in the middle of the defrost water collector and it is probably blocked - usually with ice. dry ot the tray and put very hot water in to melt the ice. you may have to do several times. do this until water flows away freely
Jul 25, 2007 | Maytag MSD2756G Side by Side Refrigerator
Frigidaire FRT18B4A Top Freezer Refrigerator Logo
119 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
