Question about Asrock P4VM800 Motherboard
Asrock motherboard 3 continous beep sound when power was stated
  • Anonymous Jun 02, 2008
    I also get 3 beeps at startup
    cant get the error codes for the bios tho'
  • 1,342 Answers
Look HERE for a list of bios beep codes
Posted on May 18, 2008
  • 3 Answers
Beep Code Manual
3 beeps Base 64K RAM failure. There is a problem with the first 64K of system memory.
Posted on Oct 30, 2008
P4VM890 - 3 long beeps
1) Son follow Anti-Static Procedures?
Ram Memory could be cr@p now if not.
To include motherboard, processor, and graphics card; IF used.
2) All power cables attached to motherboard, AND tightly?
3) AMI BIOS 2.3.1
BIOS Beep Code - 3 Beeps
Indicates Ram Memory failure.
Cracked motherboard at ram memory slots, due to too much pressure being applied to motherboard, while in computer case?
Cracked motherboard at ram memory slots due to, user inadvertently had ram memory turned around backwards; and tried to install?
(Locating Notch was not lined up with Locating Lug, in ram memory slot)
4) We all get in a hurry sometimes, and make mistakes.
(Seen those commercials? Ha!)
Is there a 'stick' of ram memory in Slot 1? (DIMM 1)
That is the ram memory slot the Processor reads first.
5) I gotta' tell ya, Fred; I think we are dealing with a Static shock issue here, or cracked motherboard.
Was working, then ram memory removed/reinstalled; and now Not working.
For additional questions please post back in a Comment.
Mar 15, 2013 | Asrock P4VM890 Motherboard
No video on asrock p4i45G motherboards
Hello the homepage is here:
3 short beeps: base 64 k ram failure.
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Read more here:
Beep codes:
The fault could also be: power supply, or bad capacitors on the mainboard.
Good luck
Nov 26, 2012 | Asrock P4i65G Motherboard
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
Asrock p4vm8 beep codes
How does it sound? Does it beep with memory card seated? one long- 3 shorts beep bad graphic card, one long repeated 3 times bad memory card
Apr 12, 2010 | Asrock P4VM8 Motherboard
Contineous beep no video
Continuous beep is a bios code for a faulty powersupply or motherboard, take the power supply out first, and test it in another pc, if it works its your motherboard.
hope this helps.
Apr 04, 2010 | Asrock 845GV (P4I45GV) Motherboard
P4vm800 not working how to solve this probelom
Good day sir, hi, lets make sure first that your motherboard is good, so we need to test it, just prepare the folowing items.
  1. A good working power supply, to test: place a jumper wire across the green wire and any black(or sometimes the red with work) wire on the 20/24 pin power connector. Plug it and see if the exhaust fan run.
  2. A good set of Ram, just make sure its good. if not or in doubt buy new one (only one module) if you want. (you can keep the doubtful ones and test it later)
  3. A keyboard.
  4. If your motherboard has no VGA onboard, A good VGA card.
  5. A thumb speaker, or you can use your PC case speaker.
Okay lets assemble, on a table:
  1. Place your motherboard, (make sure no metals underneath) connect the Power Supply 20(or 24) pin to your motherboard and the 4 pin 12v connector. (if your motherboard has one).
  2. Connect the pc thumb speaker or your case speaker.
  3. connect the keyboard.
  4. connect the RAM, make sure it clicks as you install it.
  5. Optional VGA card. Onboard vga will do. Connect a monitor. plug in the monitor.
Okay, plug in your power supply, (exhaust fan is off at the moment) locate the power button pins, short them with a screwdriver. (fan is now on)
Now check your Keyboard. you will see two sets of lights, first set is Num Lock + Scroll Lock + Caps Lock, then a few seconds the second set: Num Lock only. at this point your motherboard is good.
Also check out the PC speaker beeps.
  • 1 beep mean good.
  • 1 long and 3 short beeps VGA is bad. (it may help if the VGA is snug and fit on the slot). If on board VGA, use a new AGP/PCIe card.
  • Continous long beeps. cannot detect memory
  • Continous short beeps, motherboard. (or memory sometimes).
  • No beep, fan is this point do everything again. (do it several times until the board responds)
Hope this helps you. feel free to ask again.
Oct 14, 2009 | Asrock P4VM800 Motherboard
Asrock K7S41/K7S41GX problem
2 x DDR DIMM slots
- Supports DDR400/333 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
3 beeps is usually either video card related, or memory. be sure your memory is UN buffered, and DDR400 or 333 DIMM not DRam.
Remove and re-seat your video card as well.
there should be a troubleshooting guide in your install manual stating the designation of 3 beeps.
Dec 22, 2008 | Asrock P4VM890 Motherboard
ASRock K7S41 / K7S41GX, sound 3 Beeps 3 times, then power off automatically
I had 3 beeps, pause, 3beeps, pause and so on.
Defective SMD transistor near the ATX power connector. Original is a 2SB1202 (marking B1202).
I bought a 2SB1203 which is stronger and soldered it in. The K7S41GX board runs as fresh as from the dealer.
Aug 27, 2008 | HP Compaq dc5100 PC Desktop
Can u help me?
check the video card of your system. if it is add on card , remove it and clean. if still error exist then maybe u need another VGA.
Jan 10, 2008 | Asrock 775VM800 Motherboard
No display on monitor
Can be a problem with any of the components.
Do the power supply, cpu fan and disks start to spin after power up?
Does the PC speaker sounds a sequence of beeps? Can you identify a pattern, like 3 short beeps indicates a memory problem.
Keep posting so we can zoom in on the problem.
Dec 28, 2007 | Computers & Internet
Asrock P4VM800 Motherboard Logo
1,165 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
