Question about Hitachi 43FDX01B TV
53 INCH HITACHI RED CONVERGENCE
Red color is about 1-2 in. to right of picture. I know it's the red convergence, but I can't find any info on where to purchase a new part, or where it's located in tv. please help:53FDX01BA
    Genius:
  • Hitachi Master
  • 1,635 Answers
This is a defect most likely on the convergence board.
You should have the manufacture authorized service people repair the set. You can end up buying a convergence board, and the service manuals, and still have some other faults.
For information and parts, look up the Hitachi home page on the net and go to their support area.
Jerry G.
Posted on May 19, 2008
My Hitachi 43fdx01B went from a perfectly clear picture to one with red "ghosts" and very blurry. I my TV toast?
No,ur tv have a problems,known as a convergence problems,it dead.Very common problems on the DLP tvs design flaw.Most commom problems are R,G,B mis alignment,will not align,Colors shadows pictures,3D pictured and blurry?The tv convergence board require changing the 2 STK convergence ICS and some or all it resistors are dead,must changes to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 26, 2010 | Hitachi 43FDX01B TV
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
Hitachi 51S715 white grid lines are bowed at top and picture is now bowed also
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | Hitachi 43FDX01B TV
I have 46ux13k hitachi tv and i need to know if there is atrick to adjusting the convergence.
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACHI REMOTE. NONE ELSE WILL DO
1. Receive an NTSC signal.
2. Press Magic Focus to begin magic focus
3. Press magic focus again during the magic focus process to get the “stop” screen.
4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
5. When you first get in here? I believe red is the selected color by default (it is flashing).
6. To choose other colors to converge, use the following buttons on the R/C:
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
ONE COLOR WILL NOT MOVE. YOU WILL NEED TO MOVE OTHER COLORS TO ALIGN TO IT.
7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
· Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
· Use thumb stick to move the convergence point color.
Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Turn power OFF.
18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
Mar 21, 2009 | Hitachi 43FDX01B TV
Hitachi43fdx01b had convergence issues, now screen is dead
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 04, 2008 | Hitachi 43FDX01B TV
Top left corner double picture red and green
you have a failed IC resistor usually you can physically see the bad one because it burns out leaving you to guess what the value was. Hitachi offers a convergence fix kit which has 2 IC's and all approiate resistors.
Sep 01, 2008 | Hitachi 43FDX01B TV
Hitachi 43FDX01B Convergence Problems
Hitachi remote part # HL01643........I like the original remote
to do adjustments.................T.
Aug 06, 2008 | Hitachi 43FDX01B TV
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
Hitachi 43FDX01B convergence red line wont move
probably need to replace STK IC on convergence board and possibly associated low value resistor
May 09, 2008 | Hitachi 43FDX01B TV
Hitachi 43FDX01B (convergence) problem
Convergence IC's must be changed to start repair..original...
STK392-110 sub to Hitachi upgrade STK394-160E.....PART #
CZ 01341...you need two....
Next, take a critical look at the B+ feed resistors near the IC's..
check for over-heat / damage......usually 2.2 ohm 2 watt......
Let me know....................T.
Jan 03, 2008 | Hitachi 43FDX01B TV
Hitachi 43FDX01B TV Logo
156 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
