Question about Equator EZ 1612 V Front Load Washer / Dryer
When the Handle broke off the door
I can't understand why they would design and manufacture the door handles of 2 small tabs of plastic but they did. And now my handle sits on the floor next the washer, and my laundry inside. What to do?
SOURCE: Handle
I order mine online from appliancedesk.com. I have one ordered now. It is on backorder. When you install new, be sure to mark position of door inserts, just in case they separate and you have to figure out how to reposition them.
Posted on Apr 23, 2008
SOURCE: broken door handle...
I have the same problem and I have a makeshift solution which I was able to do in 45 minutes and total cost was less than $1.
Step 1: Remove door from machine.
Step 2: Disassemble door with the two plastic donut shells. This means removing 6 or so flathead screws. Take care to note alignment of glass parts because they aren't perfect circles and only fit one way.
Step 3: Pull out pin that threads the spring and broken plastic handle remnant and metal latch piece.
Step 4: Discard broken plastic and replace the rest of the apparatus. The metal latch can move up and down, but that's ok.
Step 5: Purchase a paint-can opener:
http://www.istockphoto.com/file_thumbview_approve/525566/2/istockphoto_525566_opener_for_paint_can.jpg
Step 6: Re-attach door.
Step 7: You can use the paint-can opener to the right of the latch to lever-open and lever close the latch in order to open and close the door.
Cheap, easy. Not pretty at all. Definitely something your friends would make fun of you for doing, but it saves you $1,000 of a new machine, in this economy.
Posted on Jan 17, 2009
  • 37 Answers
SOURCE: Door handle for Equator EZ 1612 V
If you are still waiting for this part you can purchase it from www.appliancedesk.com click on shop parts.
Posted on Feb 25, 2010
  • 37 Answers
SOURCE: Equator EZ3612 CEE
If you still need assistance on this let me know and I can provide you with the procedure for the same.
Posted on Feb 26, 2010
SOURCE: Door is locked, handle is broken, how do I open the door?
Yes, follow the above instructions to open the washer. It happened to me last night. The machine was still locked and when I went to open it, the handle just broke off. You have to push the part in (where the plastic handle was) and use a screw driver to pull open the door (simultaneously). I was able to find a company in Toronto/Mississauga called Rapid Service who carry the parts and provide service for this machine. The door handle costs $55 and can be installed by yourself (at least if you are even slightly handy). I hope this helps others who come across this problem!
Posted on Jun 01, 2010
How to replace the door handle on a whirlpool MH2155XPQ micro wave
The screws that hold on the handle are inside the door assembly. Here is the way its done but its not for the average person. On the inside of the door is a plastic frame all the way around the door. It is held in place by plastic tabs. You have to gently pry off that frame with something like a putty knife or small screw driver. If you are not careful you end up breaking off some of the tabs. Once that frame is off you should have access to the 2 screws holding on the handle. Remove screws---replace handle---and push plastic frame back on.
Jun 26, 2015 | Whirlpool MH1150XM Convection/Microwave...
Door handle broke
can you open from the inside, its the only way you going to get to sort this, failing that you may need to get a new door card and rip the one off the door at the top corner near to the lock latch and split the plastic and pull the door pin inside to open then take the door card off. sometimes you can do it with out braking the door card but would not say it will not brake. inside there is a plastic clip that the handle go's on then another bar to the lock. this is designed to snap if some one trys to open the door with force.failing that the handle part can snap where the bar fits to it. that you would need to change the handle.
Dec 06, 2013 | Land Rover Cars & Trucks
The front passenger door will not open with the outside door handle or the interior door handle. after taking the inside door cover off, i discovered the interior door handle is broken and the connector...
The locking mechanism is manufactured with carbon composite and plastic levers that the door handles attach to. It is hard to tell what parts that you do need. Remove the passenger side door panel. It will have some screws and maybe a bolt on the inside handle. The panel has snap plug on it and they fit into designated hole in the door. After getting the door panel off, be careful here, there are sharp metal edges that can cut. There are some peep hole to see the rods and connector inside the door. If the plastic hooks on the door locking mechanism are broken. The hole door lock assembly will need to be replaced.
Try your local wrecking yards and tell them what type of vehicle you have and year. Also, state what door it is and what you will need.
Now, if the interior door hand hook on the lock mechanism isn't broke off. The get a cloths hanger and straighten it out and attach it to the opening latch on locking mechanism. This will give you inside temporary handle, while you are trying to fix the door. Safety. GB...stewbison
Sep 06, 2011 | Nissan Sentra Cars & Trucks
The plastic door handle on our GE Spacemaker XL microwave oven (JVM1341WW 002) broke. I ordered and now have replacement handle and screws onhand. How do I gain access to inside of the door to replace...
I do not know your unit specifically but a lot of them you have to start by, slowly, from the inside of the door, lifting up on the choke that runs along the outer inside edge of the door. It looks like a plastic trim part about 3/4 of an inch wide. You slowly work around the whole door unit you get it popped out. a butter knife or steak knife works pretty well . I just use a small flat head screw driver The screws for the handle are behind that choke seal. Usually 2 Phillips head screws. The choke part just snaps in place and has no screws to put it back, just push back in place and you will hear it snap as you go. Be careful the plastic tabs are easy to break off
Aug 19, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Why does the door on the microwave keeps breaking below the handle
I have had 4 microwaves and they have all been different models and makes..... It finally dawned on me it was the heat from the oven that stressed the plastic handle with a metal screw in it and made it NOT hold up. It is obviously a design error for something built to be put over heat like that.... I think the industry should pick up the tab. BAD DESIGN AND MANUFACTURERS DEFECT,``````
Dec 15, 2010 | GE JVM1631 Microwave Oven
Describe how to change the passenger mirror on a 2007 Toyota Sien
Hi, First remove the door panel. (The connector for the mirror is behind the panel just to the left of the door handle.) The arm rest cover pops off by gently prying upward at the corners near the door panel and along the outer edge of the arm rest. Then remove the 2 screws. Remove the screw that holds the door handle bezel on. Remove the little plastic plug to the left of the door handle as well. This reveals yet another screw to remove. Now you can gently pull the door panel away from the door. The little plastic clips will pop out of the door. If they come away from the door panel they easily fit back in place in the metal retainers built into the door panel. You can now disconnect the connector and remove the 3 10mm mirror bolts.
With respect to the door handle bezel on the inside of the door, to remove it you must pull/slide the bezel away from the door hinge. It should move an 1/8 to 1/4 inch. There is a little tab that hooks inside the door handle mechanism and two small holes, top and bottom, that slip over little pegs on the mechanism. I broke this tab while removing the bezel on my car. This was the most difficult part, on my car, to remove.
Take care
Jul 23, 2010 | 2007 Toyota Sienna
How to replace a door handle on a 2006 hyundai sonata, i either broke the handle and need to replace it or I am trying to figure out how to fix the drivers side handle
Step1: First, unscrew the 7 screws holding on the door panel
Step2: Next you carefully pry off the tweeter cover that is where the mirror is.Lift the panel up and off of the door . Undo all of the wiring connections except for the window controller.
Step3: Open the 2 black rubber view ports (Circled in Yellow) and roll the window up or down until you see the 10mm bolts that hold the window in place.
Step4: Loosen, but don’t remove these bolts. Slide the window up, and tape it up, or remove the window and set aside. Next, unplug the door lock plug and move the door panel out of the way.Unscrew the gold 10mm bolts that hold on the metal inner door panel . Also remove the Phillips screw that holds the inner door handle on
Step5: Unscrew the small bolt that holds on the lock cylinder that is behind the quarter-sized black cap on the side of the door. Be careful with that little bolt or it will fall into never land .Pull the lock cylinder out and set aside.
Step6: Now grasp the door handle, and with your free hand smack your hand holding the handle towards the back of the car. This will release the door handle.Under the door handle is a Phillips screw. Loosen this screw a few turns but don’t remove.
Step7: Now undo the 3 black star shaped screws on the door lock.You can now wiggle the inside of the door handle until it comes free. See the tabs that hold it onto the door . When you go to put it back on be sure the tabs get back in the right place.Pull the whole inner door panel and lock mechanism free by wiggling it out of where it sits.
Step8: Now you can undo the 3 cables; 1 from the outer door handle yellow mechanism, 1 from the inner door handle mechanism, and 1 from the inner door lock lever.Put on the new lock and put it all back together. Be sure to test it as you go. I had to turn the lock cable to the inner door lock lever 180 degrees because it was not unlocking properly when I put it back together the first time.
A couple of other notes, there are 2 pieces of plastic that are for the robots to use when putting the door together for the first time. one is a 3 pronged white plastic thing riveted to the inside of the metal door panel. The other is a white plastic thing covering the lock mechanism. You can cut off the fingers and throw the plastic cover away they are both useless and in the way.When you put it all back together, just go in the opposite order of disassembly. It is a little tricky to get the yellow plastic outer door handle holder into place. Be sure that the little tabs grab the metal of the door or things will not fit together properly.Be sure to test the power window after you put the window back in place. Do not overtighten the bolts on the window, it is glass…..
Apr 08, 2010 | 2006 Hyundai Sonata
Replace handle on adeantium sca1001fss01
you have to take the door off and pop out the plastic molding around interior of door. You can do this by sliding a screwdriver around the edge until you can get your fingers in. Be careful because there are some small plastic tabs that will break very easily. Next, remove screws on the backing of the door. There are similar tabs holding the backing on even after the screws are removed. I used a pair of insulated pliers and used the handle to pry the tabs back. Be careful because the tabs will break easily. Then the screw handle is exposed. Pretty easy huh?!!!! I just comleted this process and am looking for a handle. I am sure I will have to super glue some areas since I broke the tabs off.
Good luck
Jun 01, 2009 | GE Advantium 120 Convection/Microwave Oven
The bottom of the door handle broke off. GE spacemaker xl
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Door handle 1996 thunderbird
sounds like a plastic Sir clip of course you say external handel detached from door consider linkage clip has fallen down!
Dec 01, 2008 | 1996 Ford Thunderbird LX
Equator EZ 1612 V Front Load Washer / Dryer Logo
113 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
