Question about JBL BP300.1 PowerValve Series Car Audio Amplifier
Jbl bp300 amp qiuts when turn on truck.
The led light is on green every thing is hooked up properly. the subs will sound distorted then the amp will not put any sound out but the light still green, if you hit the amp with your hand slightly it kicks back in? what should i do to fix this
  • Anonymous May 15, 2009
    same as above,,,lights are on but no action,,,if I hit it then plays for couple seconds
3 Suggested Answers
  • 109 Answers
SOURCE: jbl amp kiskcs in and out
Something inside the amp is busted.... stop hitting it... and replace it.
Posted on Jun 19, 2008
  • 73 Answers
SOURCE: Amp has no sound
it is posible that you used a power cable that is too small i guage and smoked the power supply
Posted on Jul 28, 2010
Amp has no sound
Jul 27, 2010 | JBL Car Audio & Video
JBL PB10 subwoofer sounds distorted and lights on the front flash
More likely to be the Class D power amp module, but you should look through the service manual to make sure all the parts are installed correctly. My PB10 AMP module went out and you cannot get one anymore.
http://manuals.harman.com/JBL/HOM/Service%20Manual/PB10%20sm.pdf
Nov 10, 2009 | JBL PB10 Subwoofer
JBL PB10 has lost power even though still plugged into wall, any suggestions?
Do you mean like the subs power lights dimming when playing it at volumes it once had no problem playing, or loss in sound, distortion?
Oct 10, 2009 | JBL PB10 Subwoofer
Bridging outputs on JBL BP300
Hello paulnkate,
The BP300.1 is a mono (1 channel) amp. You cannot bridge a mono amp. Bridging is a method of combining the outputs of 2 or more channels of a multichannel amp into a single mono load. On your amp you would connect a single sub to one of the +'s and one of the -'s (either one is OK, they are connected internally). The other pair of terminals is just for convenience, making it easier to connect, if you want to power 2 subs.
Hope this helps.
Jul 20, 2009 | JBL BP300.1 PowerValve Series Car Audio...
Not gettin enough bass
Hello saini_jatt_2, On the JBL3501 700 watt monoblock, you have adjustments for low pass and a setting for boost marked DBO, allowing you to select and boost the frequencies sent to the subs. If your amp is not the 3501, but a different JBL amp, the settings may be different. Set the LP to either the white dot (about 100Hz) or slightly below to about 80Hz. Set the HP to about midscale or slightly higher. Set the boost to wherever the bass sounds best. One other setting that will affect bass volume is the "input level" or gain control. It should have been properly set by your installer, but you can "tweak" it for best performance. Turning it up increases the sensitivity and matches it with the output from your head unit. Too high will cause distortion. Too low will result in less bass. So you want to set it just to the point that you begin to hear the distortion and then back it off slightly until the distortion disappears. Hope this helps.
Jun 05, 2009 | JBL GTO1202D Car Subwoofer
JBL Amp P80.2 - Random output failure
i had an amp that did that for a while before frying. its possible that it could be overheating causing it to go into protection mode which can be fixed with a cooling fan or remounting it somewhere else so it can get some air. it needs to be mounted in a way that it will have at least 1/2" clearance under it so it can have plenty of airflow. the other thing is you may be putting too much of a load on the amp causing it to go to protection mode. check and see how u have the sub wired and if the amp is stable. if u have the sub wired at 2ohm for more power output and the amp is only stable at 4ohm, then the amp will overload and cause the problem your experiencing. thats what happened to my amp. i had it wired for more than it was stable for and it fried
Jun 04, 2009 | JBL P80.2 Car Audio Amplifier
Jbl amp kiskcs in and out
May 18, 2008 | JBL BP1200.1 Car Audio Amplifier
Noise when it turns on
have you checked your music source? Some systems like computers have a sort of output first before normalizing, which isn't your powered subs or powered amps problem. Try plugging in a regular solid state player like an ipod if the humming is still there when automatically turning on or off...
Dec 06, 2007 | JBL PB12 Subwoofer
JBL BP300.1 PowerValve Series Car Audio Amplifier Logo
106 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
