Question about Intel Pentium 3 , 450 MHz Pentium III (SL364) Boxed Processor
How do i set my BIOS to fail safe setttings?
Hi
its techman991
you said to set my bios to fail safe settings to fix my off-frequency problem
how do i do that?
    Guru:
  • 1,342 Answers
I just replied to the previous post HERE
Posted on May 18, 2008
Acer v3-531 cant load and boot to windows 7 it was win 8 just restarts will not run. I have changed all the relevent bios setting and diabled all security in the bios and sett to legacy settings
At what stage is it failing to boot to Windows 7? Have you actually managed to boot off the installation CD/DVD or USB?
I suspect you haven't and that's the problem at a guess. You may need to disable "secure boot" in the BIOS. This prevent the system booting from other devices. Once disabled you should be able to boot from the installation DVD or USB. If you are using a DVD and have disable secure boot I would try installing from a USB drive. I have had this problem myself and the workaround was to install from USB.
If getting Windows 7 to install is not your problem, have tried starting the system in safe-mode?
Mar 20, 2014 | Computers & Internet
What stage is it failing to boot to Windows 7? Have you actually managed to boot off the installation CD/DVD or USB?
My keyboard does not work
hi there,
Here are some steps which you can try to get the keyboard respond.
You can boot to Safe Mode, Safe Mode with Networking or Safe Mode with Command Prompt (by pressing F8 before the Windows logo shows up) to see if problem occurs. You can also go to the BIOS set up (press F10) to check if it responds, reload BIOS default settings if its working.
For acer computer, I think FN+F6 locks the keyboard and touchpad, try if it works. You might as well want to scan for viruses or just reinstall the Operating System if it works in Safe Mode or BIOS, it should fix the problem.
Hope this helps.
May 10, 2011 | Acer Computers & Internet
Try to put operating system in computer comes up with overclocking failed error how do i reset or fix overclocking problem
hit F1 or DEL right at boot repeatedly until it enters bios. look for cpu/frequency, perhaps underneath "chipset" or "advanced" settings. lower the cpu/frequency a little, until it boots, or look for "auto" settings for the cpu/frequency and ram speeds.
Nov 23, 2010 | EliteGroup 945P-A (945PA11) Motherboard
Alwyas get to bios cpu freq and hang
try clearing the bios and replace the bios battery.
Check the processors correct frequency and set it in the bios and save settings this should fix the problem.
Also check if your cooling fan on the processor is tightly fixed onto the cpu and motherboard
Dec 01, 2009 | ASUS P4S333-VM Motherboard
Hi, im installing my operating system but the pc always turns off in the middle of installation(after loading setup files and displays the press enter to install windows xp). i alraedy set the bios to fail...
Dear,
First you have to see the CDROM wthere its reading correct or not? before that you have to change once RAM and try again. It will work. okey. Due to frequency mismatch it will occur.
Cheers
Jaggu
Sep 28, 2009 | EliteGroup KM400-M2 Motherboard
Monitor problem: not optimum mode recommended mode: 1280x1024 60 hz ? cannot click on screen. Samsung model 913T s
It appears your display adapter is set to a different refresh frequency or resolution,
either accidentally or due to some power glitch.
If you cannot set the resolution because this message is preventing you from getting to the
display settings window, try rebooting your PC in Safe Mode. It'll take a while longer
than usual, but when you're finally running, try setting your display adapter to the
1280x1024 60Hz settings. This is available under "Advanced->Adapter->List all modes".
To reboot in safe mode, try pressing the PF8 keys repeatedly after the POST messages
disappear just after turning the power on. This only works if this key is enabled to
operate from the BIOS settings.
To get to the BIOS setup, Look at the first messages displayed on your screen indicating what key to press. It's usually the Delete or PF2 key, but different BIOS manufacturers use different keys.
Once inside the BIOS setup, find the way to enable the PF8, PF9, PF10, keys. Save your
settings and reboot.
Now you may try PF8 again to go to Safe Mode.
Good Luck!
Aug 19, 2009 | Computers & Internet
My pc does not even display the bios setting .what should i do ? please help
when your computer boots up Does it say hit DEL for setup??? thats how you get to Bios( Basic Information Operating System) not windows . Windows is an operational syatem that runs the computer. Bios=settting for computer like where to install hardware,what handlers to assign to handle functions of the motherboard. Techs use Bios ,before setting up windows . Dont mess with Bios unless your a tech.
Jul 09, 2009 | Computers & Internet
During last bootup, your system hung for improper frequency combination. Your system is now working in safe mode. To optimize system performance & reliability, make sure the frequency combination ...
this is only a warning of computer bios., this usually happens if you overclock, or a power failure during POST of bios.. Just press the Restore/Default Setttings.. I think its F2 in some boards, itwill just reset the settings, it should be fine
Feb 02, 2009 | ASUS P4B533-VM Motherboard
Intel Pentium 3 , 450 MHz Pentium III (SL364) Boxed Processor Logo
123 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
