Question about Samsung Refrigerators
I moved our 18 month old samsung fridge freezer Model SR281NW and one week later it has stopped working. The freezer fully defrosted and the fridge, even though it has the light on, is not cold
  • 828 Answers
Is the compressor trying to run at all. Are any sounds coming from the area of the compressor? Like a hum and a click sound in that order? If the compressor is cold to the touch it could be a control problem. If the compressor is cold there are two things that shut its power off. The thermostat which controls the temperature or the defrost system. If the compressor is hot the problem is compressor related.
Posted on May 18, 2008
How do I fix my GE refrigerator?
Ge uses a glass heater and it is common for the heater to go out replace the heater and it should cure your trouble
Dec 27, 2015 | GE Refrigerators
RS267LBSH The refrigerator stopped working. The technician came and replaced the compressor. It works for 1 1/2 month and failed again. He came the second time and replaced the evaporator. A month
your getting ripped off try the defrost timer sounds like it is getting stuck, it operates on a 24 hour basis cycling between defrost, and turning compressor on and fan to cool the fridge
Sep 02, 2012 | Samsung Refrigerators
Amana French Door Fridge - less than 18 mos old. Issue: stops cooling about every 2-3 weeks. Solution has been to empty fridge, unplug, open all doors, put fan in freezer and 'warm down' the...
Since you did not inclde a model number this is a generic response. What your describing is caused by the unit not automatically defrosting.
The parts of the automatic defrost system are:
1. The defrost control / This can be a mechanical clock timer or electronic adaptive defrost control
2. The defrost heater
3. The defrost thermostat or thermistor (depending upon model number)
One of the three has failed. I doubt #3 (thermostat or thermistor) is the problem as it would usually cause the unit to stay in the defrost mode and everything would thaw out.
You can find parts by going to this page:
You must choose servicer and then enter your model number to get the parts manual.
If nothing else... download your parts manual and look up the parts that are replaced on your unit to see if you got a fair shake on your repair. Just net search the part numbers.....
Thanks for choosing FixYa,
Jul 28, 2011 | Refrigerators
I have a Samsung side by side model # SRS 632NSS. it is about 18 months old. The freezer side does not function but the fridge side is normal .We have tried turning it off and resetting it however it is...
Defrost cycle is very often. Check freezer timer/thermostat might be cuts off frequently. Check thermostat setting..Check fridge is working continuously until frosting over freezer by keeping thermostat at 9' clock position. If not replace thermostat.
Jan 30, 2011 | Samsung RS2630SH Side by Side Refrigerator
I have a Samsung fridge SR281NW and the fridge section doesnt get cold.I was wondering if it was as simple as replacing the thermostat or is it more involved?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Jan 28, 2011 | Samsung Refrigerators
Whirlpool 445L white Fridge Model: WRID41TW It started with dripping water into the fridge from top (freezer?). I was unable to locate the water source. Three days later, the freezer started frosting...
Have you tried it after letting it defrost for a couple of days . It sounds like it was just frozen up. If the freezer is still working then it is the defrost drain is frozen up.
Oct 14, 2010 | Whirlpool 17.6 Cu. Ft. Top-Mount...
My samsung fridge 18 months old. the freezer is working so so, however the refridgerator is not working at all any ideas.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Aug 27, 2010 | Samsung RS2578BB Side by Side Refrigerator
I have an active smart fridge freezer. The freezer seems ok but the fridge has stopped working but it doesent get cold. how can it be fixed. It is only 18 months old.
Check fan in the freezer
Also check auto defrost (ice on the freezer coils anot allowing
air to the fridge.)
If so go to appliance parts store to learn the parts to fix auto defrost.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
Aug 07, 2010 | Fisher and Paykel Active Smart E522B...
Our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram.
Sep 09, 2009 | Samsung RS2630WW Side by Side Refrigerator
samsung fridge freezer problem
samsung fridge freezer diy help
Apr 27, 2009 | Samsung Refrigerators
Refrigerators Logo
246 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
