Question about Olevia LT37HVS 37 in. LCD HDTV
Olivia - Model 532H 37inch LCD TV
Got the tv out of the box plugged it in, connected the cable to it. No picture, no sound. The little blue light on the front of the tv is on, but nothing elce works. Help - I'm sure its simple - but I don't see it.
  • 2 more comments
  • calla_lady Jun 28, 2008
    Blue Screen - No signal I can get the menu, go to setup and switch to TV and it showes channels but doesn't go any farther.
  • Anonymous Aug 01, 2008
    tv stays on for one or two days then starts shutting off by itself and won't turn turn on or off. have to turn power off and back on and still does'nt work.
  • bigwater Nov 25, 2008
    i was watching the tube, i turned it off and it never turned back on. the little blue light on the front is still on but nothing else. (and the little blue light turns off when the tv is turned to the on position)
  • dlh9 Apr 18, 2009
    I olivia went to a small screen. When we got it back to a full screen it had a small blue box in the lower right hand corner kind of like a pip but there is no pip button on my Olivia
I would give you all to look at this gentleman who has provided a step by step guide to solve this problem...
It should sovle the problem. It is a powersupply parts quality problem and I think we should all write to Olevia to provide support for such inherent problems in their product.
I will write to them... I think if a bunch of people write it would make a difference.
Posted on Oct 22, 2008
  • 3 Answers
You must run set-up with the remote control.
It came with your package.
Read instructions.
Posted on Sep 04, 2009
  • Olevia Master
  • 5,568 Answers
I don't know if this applies to your set but the blue LED on our 47" Olevia is ON when the set is OFF.
It extinguishes when the power is turned on.
I guess the assumption is that when the set is on, who needs any LED?
Posted on Jun 11, 2008
    Problem Solver:
  • 5 Answers
I work in a casino and do repairs like this regularly...I just wanted to note...if you replace the obviously domed should replace all of them...chances are they have all become weak...and you don't want to have to do this again
Posted on Sep 03, 2009
Need help troubleshooting TV
You need to check your inputs. Make sure your tv is set to the same input that you are plugged into. Ex. If you are plugged into HDMI 1 then your TV SOURCE needs to be on HDMI 1.
Dec 30, 2015 | Vizio 37inch VO37LFHDTV1A FULL HD 1080P...
My 19 inch Emerson tv screen has went blue an no picture isn't showing
Sounds like a bad connection to whatever you have it connected to (cable box, dvd player, etc). Check the connection and then replace cables.
Feb 13, 2015 | Emerson LD195EM8 19 in. LCD TV
I have a Magnavox HDTV 12' by 9" screen, Model number 15MF605T/17 The TV turns on and there is sound, but no picture. any suggestions?
check the connections in the back of the tv. If you are using a cable/satellite box, what sort of cable connects it to your tv? If HDMI then you should have sound and video thought that one cable. If component (5 plugs in total red,green,blue, and audio red/white) make sure the red green and blue plugs are seated in all the way on both the tv and the cable box.
Jul 18, 2011 | Televison & Video
Does ovelia model 532 B-12 come with built in tuner.
I purchased a 532-b12 several years ago - it includes both an analog and digital tuner.
Feb 13, 2011 | Syntax Olevia 532H 32 in. LCD HDTV
Blue screen: Not Support!
It sounds like you have no signal being detected by the TV. Check your connections to the TV from your cable box or satelite reciever to be sure they're plugged in tightly. If you have a DVD player or VCR, try watching something from one of them to see if you get a picture. If you do, then your problem may be with your cable box or satelite reciever, and not the TV.
Good luck.
Dec 01, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
Blue picture
It is your "vergin media box" outputting a blue screen!
When this TV has no input it displays a msg box "No Input Signal" or "Signal out of Range" (PC video resolution is not correct.)
Jun 26, 2009 | Hyundai Electronics E465D 46 in. LCD TV
New setup
do you get anything on screen, like the menu or channel number?
Feb 05, 2008 | RCA L42WD250 42 in. LCD HDTV
Lcd tv black but green power light on
If you're using a cable box , connect box to tv using component cable .
Jan 04, 2008 | iLO 3200 32 in. LCD Television
Olevia LT37HVS 37 in. LCD HDTV Logo
649 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
