Question about Panasonic Televison & Video
Panasonic PT-61HX42F, Need service mode code to correct colors on projection Monitor. My colors are off and they will not come together in convergeance setup...
  • garrybourn May 18, 2008
    I know that already and i will replace that soon. I still want the service code setup, so i can adjust for fine, coarse. Not only do you need to replace IC's, but there are several adjustments in service menu to be performed to do it correctly. So, if anyone can help me get the code for service mode that would be great.
  • garrybourn May 19, 2008
    Hey thanks that was real quik, I was almost going to have to purchase the manual.. I have the bench tech schematics for voltages, current, etc.. I just needed to get in there for final adjustments. Works perfectly
    Thanks again
    garry
  • Panasonic Master
  • 8,617 Answers
The service menu wont help. you need to replace both convergence ics number STK392-110 . you can get replacement ICs at the following link and they provide free instalation instructions with pics so you acn do the repair yourself in about 45 minutes and save over 400.00. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 18, 2008
  • Sonny Berry
    Sonny Berry May 18, 2008
    Using the remote control:
  • Press the {MENU} button.
  • Press "Setup" menu.
  • On "Mode" menu, select "Cable"
  • Select "Timer" menu and set sleep timer to 30 min.
  • Press {ACTION} twice to exit menus.
  • Tune to channel 124.
  • Press and hold {VOL -} button ON THE TV.
    "CHK" appears in on top-left corner followed by 5 letter/numbers
    (which are the cumulative hours in hex numbers)
  • While the "CHK" is displayed, press the {ACTION} & {VOL+} buttons
    ON THE TV simultaneously to toggle between Modes:
    — Red "CHK" for Serviceman — Yellow "CHK" for Aging —
  • Press the {POWER} button on the remote to select one of the six
    Serviceman Adjustments Modes.
    A. MTS ADJUSTMENT
    B. CLOCK ADJUSTMENT
    C. VIDEO ADJUSTMENT
    D. HDEF ADJUSTMENT
    E. VDEF ADJUSTMENT
    F. DAF ADJUSTMENT
    G. OTHER ADJUSTMENT
  • Press {CH+} {CH -} on the remote to select the settings
    on each of Service Adjustment Modes.
    Write down the original values before modifying anything.
    It's easy to erroneously adjust the wrong item.
  • Press {VOL+} {VOL -} on the remote to change values.
  • Press the {POWER} button on the TV to exit the service menu
  • wbi1984 Feb 08, 2011
    MY PANASONIC PT-61HX42F THE COLORS HAVE GOT ALL OUT OF WHACK AND ARE PURPLELISH I HAD THIS PROBLEM BEFORE IS IT THE LAMP? I HAD THE TECH COME BUT VERY EXPENSIVE I DONT HAVE THE MONEY DO YOU KNOW WHAT THIS COULD BE AND WHAT THE PART IS CALLED?
    I have a Panasonic pt-61lcx65 and everything works fine but in the picture there a outline of green and shades of green on the picture, and I've tried everything to get to the service mode to adjust the...
    I own the same set in the 44" version. These often need a "prom flash" with the panasonic programming jig to correct for color spots" in the picture. Mine did, over 3 years ago and has bee ok since.
    Apr 30, 2014 | Televison & Video
    Panasonic pt-52lcx65-k color problem
    I have the same problem. i called panasonic they said it was a on
    going problem and they would send out a repair tech no charge to
    fix problem.give them a call 1-888-843-9788
    Jan 04, 2010 | Panasonic PT-52LCX65 44" HDTV
    Panasonic PT-52LCX65 now has a red color spot and purple color spot on screen. I had purchased an extra lamp and replaced but didn't help. Is it color wheel or something else?
    Howdy,
    The problem is with the EEPROM in the TV that needs to be reprogrammed. But you need to have the proper Correction Tool (LSUQ0100).
    I don't think it's available to the public. Call a Service Company, but make sure they have the “Correction Tool”.
    Thanks for using FIXYA, big IRISH.
    Jan 01, 2010 | Panasonic PT-52LCX65 44" HDTV
    Color spots on screen panasonic pt-61cx65
    Howdy,
    Nov 13, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
    Panasonic PT-61HX42F shuts off automatically red light flashes, but before that happened the green color was way off
    One of the convergence output IC's has died. However, when one goes the other is soon to follow so any good repair shop will insist on changing both of them. This is a common failure with all projection tv's as these amps work real hard and have a high failure rate. Average repair cost is usually between $200 and $300.
    Jun 04, 2009 | Panasonic PT-53WX42 53" Rear Projection...
    Convergence problem
    Hi, you`ve lost the convergence IC`, requires a good knowledge of soldering and. posssibly an alignment after replacement, good luck, video-tek
    Feb 14, 2009 | Panasonic PT-53WX53 53" Rear Projection...
    Alignment issue - PT-47wx49 Panasonic PTV Tubes out of align
    your convergence is off. u need to get in service mode to correct this problem. its pretty in depth and time assuming. u need to go to servicemanuals.net and for 15 bucks u can get a service manual. it has every thing u need to fix that tv. i had same problem but i had all 3 colors out of whak. i see alot of people on this forum changing the ic's and resistors to fix convergence problem, (me too)and nothing works. i got this manual and saved me alot of money. its been 3 months since i corrected it and i am still watching it. good luck.
    Nov 24, 2008 | Panasonic PT-47WX49 47" Rear Projection...
    Panasonic PT-61HX42F turns on, but wont stay on.
    you need to change the stk 392-110 (2 ic ) and some resistor around the area ok
    Sep 08, 2008 | Panasonic PT-61HX42 61" Rear Projection...
    Exiting service mode
    All different brand of PTV has there way of excisting out of the service mode, panasonic don't list it, very hard to do, turn tv off then you see.
    What about Bob
    Mar 01, 2008 | Panasonic PT-47WX42 47" Rear Projection...
    Televison & Video Logo
    235 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
