Question about GPS
Magellan Maestro 4250 GPS Power Failure
We just bought the Magellan GPS and now we can't turn it on. In the course of two days it work fine. Seems to have no power or maybe the on/off switch isn't working??? Tried home outlet, car outlet, and computer power supplies. Tried using the reset button. Nothing. Any ideas?
  • 1 more comment
  • karen3480 Jul 31, 2008
    I'm having the same problem I just got mine Sunday. If I leave it alone for a while it works again. I don't know if it's defective or I'm not holding the button long enough or too long.
  • Anonymous Aug 06, 2008
    Me too! We used it a few times and then poof... "rhonda" didn't work anymore
  • drblakeside Mar 23, 2009
    Cannot turn the power on.  It did work for a few months and then all of a sudden the unit stop working.
    Problem Solver:
Hi guys. No need to panic. I thought I had the same problem when I got mine but actually there is no problem. Somehow, the off-on switch on the system is kind of funny. U really have to have small finger and depress the switch as far as u can until the system comes on. Might not be the fix you're looking for but give it a try anyway. Nothing to lose. Good luck.
Posted on Aug 20, 2008
Owned 3 Magellan 4250 Gps, was working, now no sound.
Make sure the font selected is a TTS ( text to speech)
Jun 05, 2010 | Magellan Maestro 4250 GPS
I tried to upgrade my Magellan Maestro GPS 4250 with the new firmware that Magellan sent. In the process, I accidentally erased all my data in my 4250 and now inoperable. Please help. Thank you.
if you still have the original DVD that came with the device, i think you can use that to upload them maps and other info, but of course this will just be like having the device brand new.
Aug 20, 2008 | Magellan GPS
Magellan Maestro 4250 GPS, the display seems to wash out on sunny days so that it is unreadable. That's without direct sunlight on the unit. Can anything be done or adjusted?
The Magellan 4250 LCD display brightness settings does not do much. I can understand how annoying it is to have the sun's glare on the display making it unreadable. You can improvise a simple sun shade like i did, cut and fit a card board strip on top of your GPS unit to block out the sun glare. It's just simple and cheap solution.
Mar 25, 2010 | Magellan Maestro 4250 GPS
Our Magellan Maestro 4250, came on by itself and will not turn off.
is it plugged to AC charge when it comes on?
If not seek out the RESET hole and place a fine pin or paper clip end in and reset the unit
Jun 20, 2009 | Magellan Maestro 4250 GPS
Magellan Maestro 4250 fuse
It is a Fast Fuse Glass type 5 x 20mm, 2A, 250v. Magellan 4250 can only take 1A of current at 5Volts Radio Shack
Jun 10, 2009 | Magellan Maestro 4250 GPS
Magellan Maestro 4250 freezing up
I just purchased a referb from TigerDirect and the only issue I discovered was a lockup when the unit goes to sleep. Try holding down the power button for 15 seconds then release it to cycle the unit. Then hold the power button down again for 5 second to start it back up. I had to do this for my bluetooth to work and not freeze up. Now I just turn it on and off manually and avoid having it go to sleep. I also downloaded the firmware update to 4.86, you can download it from Magellan's website. My unit works great so if that doesn't work contact Magellan and I'm sure they will have a solution.
May 29, 2009 | Magellan Maestro 4250 GPS
I HAVE MAGELLAN MAESTRO 4250 AND TOUCH SCREEN IS NOT WORKING WHAT CAN I DO THANKS
I got the touch screen from ebay, with search key word "4250 digitizer".
May 26, 2009 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4250 2008/2009 Map Update will not update my GPS
I also had problems with a refurbished Magellan 4250. The paperwork inside said to install the 4.85 firmware update which I found would not work with Windows XP Home at least for me. I used my laptop which has Vista Ult 32 bit it updated with no problem that is so far the only solution I used.
Apr 21, 2009 | Magellan Maestro 4250 GPS
No a practical solution, but at least you will get your device repair, after being on hold for 40 minutes I spoke to a very nice rep, unfortunately evethough she didn't admit it, it seems a software problem with the new 2008/2009 map update, in other words no way to fix it, you need to send it for repair, make sure you tell them to update the device with the new 2008/2009 Maps, if not you will have the same problem later on, Good Luck
Jun 25, 2008 | Magellan Maestro 4040 GPS Receiver
Maestro 4250
Maestro 4250 is frozen. HELP ;-(
Dec 26, 2007 | Magellan Maestro 4040 GPS Receiver
GPS Logo
494 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
