Question about H&B CA-8050BT CD Player
How do i change form radio to Cd or ipod
I keeping pressing the mode button to change from radio to the cd player but when i press mode all of the buttons just light up blue. How can i change from radio to cd or to inout so i can hook up my ipod?
  • 3 Answers
Do you have the problem since the moment you instaled the stereo. I´m not sure, but it is possible that you have done a wrong conexion. In some cars (ford, opel, etc) it is necessary to cross red and yellow cable in the iso connector in order to get the correct operation of all funtions. I had to do this in my ford focus, but I do not warrant that it'll work with your stereo. You may also ask your dealer about the original power suply conexion so you don´t burn a fuse on a wrong conexion trial. Hope it helps.
Posted on Jun 15, 2011
How to change the time
Press the MODE button 3 times, the hour digits blink.
2. To set hour, turn the VOLUME wheel to obtain a desired value.
Note: Make sure the hour is set so that the AM or PM indicators are displayed correctly.
3. Press the MODE button again, the minute digits blink.
4. To set minute, turn the VOLUME wheel to obtain a desired value.
Set 12/24 Hour format
5. Press the MODE button repeatedly to enter 12/24 hour format setting mode, "H12" appears and flashing.
6. To select H12 (12Hour) or H24 (24 Hour) format, rotate the VOLUME wheel.
Exit setting mode
7. To save all settings and exit the setting mode, press the SNOOZE button.
Apr 05, 2014 | Jensen Docking Digital CD Clock Radio for...
When I press the FUNCTIONS button it should go to FUNCTION CD, Radio MPS, USB etc but nothing!
I suspect that you should be pressing the mode button and then the function button to change what you want in the mode.
Apr 01, 2013 | Audio Players & Recorders
I have a KDC-PM445U kenwood stereo and the problem is that it won't play any music, on the display it shows that it's reading the iPod or CD but there's no music. But when I play the radio then it plays...
Firstcheck whether it is still in demo mode. to cancel demo mode -- press [enter]when message flashes "to cancel DEMO mode press ENTER key" for 10-15 secs. Turn the control knob to "YES" and press ENTER key. If it still fails to operate properly press the rest button to return to factory settings(The reset button is behind the front console)
Dec 30, 2010 | Kenwood Kdc-mp445u Car CD / USB/ MP3...
Does the TEAC CD x60i with ipod capabilities include an alarm system that wake u up with music from the the ipod that u have pre select?
The unit doesn't have an alarm, but it does have a timer that allows you to set it turn on at a certain time and off at a certain time. Not exactly the same as an alarm clock.
Press the timer button until "timer" indicator and "on" appear in the display. Hour will flash. Press the skip button to change the hour then press the time button. Press skip to change the minutes, then timer button. You now change the off time the same way. The next push of the timer button has set the time. But, now use the skip button to select the source. Pressing the timer button this time will advance to the volume setting and again advance by the skip button. Timer is now set. Make sure your source is ready to play (station on tuner, CD has a disc or iPod is connected).
May 06, 2010 | Teac CD-X6 CD Player
Ipod not working on a JVC KD331 cd/radio car player
Check your stereo for a button that says "Aux" or a "Function" button. It could also say something else depending on the radio. The one in my 93' Mustang says "Band" and in my truck it simply says "iPod" Just mess around a little bit and see what you find.
Apr 11, 2010 | Car Audio & Video
Manually change radio stations?
Here is how to manually tune your radio.
1 Press the SOURCE button until a radio
frequency appears in the display.
2 Press the BAND button repeatedly until the
desired radio band is displayed.
Each press changes the band:
→ F1(FM1) → F2(FM2) → AM
3 Press the TUNE button repeatedly until "DX
SEEK" and "SEEK" disappear from the display.
NOTE
The initial mode is DX SEEK.
4 Press the g DN or f UP button to move
downward or upward one step respectively until
the desired station frequency is displayed.
NOTE
The ST indicator or STEREO indicator appears on the
display when a Stereo FM station is tuned in
You can also look at your manual here for any other ? you might have
http://akamaipix.crutchfield.com/Manuals/500/500CDM7874.PDF
Dec 17, 2008 | Alpine CDE-7858 CD Player
Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Jul 23, 2008 | Alpine CDA-9805 CD Player
Stuck in IPOD mode
try pressing reset button ... located behind the face on the front of the radio ... after disconnecting from your ipod
May 25, 2008 | Alpine CDA-9885 CD Player
Clock settings
Phaedrus De Wolf--
To set the clock on the pioneer DEH-P2900MP Detachable face radio/CD/MP3 Player, follow the following steps in order.
Press the large round knob and hold for 5+ seconds to tuen the radio "off".
Once the radio is off press and hold down the large round knob 5+ seconds to enter clock set mode. (Note: You must hold the knob down otherwise you will just turn the radio back on.)
Now choose the < or > button next to the large knob to toggle between hours and minutes. Rotate the knob to adjust the digits.
When complete press the radio/sat button @ the top right of the stereo face.
When finished, quickly press and release the large knob again to turn the radio back on.
Nov 26, 2007 | Pioneer DEH-P2900MP CD Receiver...
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Jul 01, 2007 | Kenwood KDC-MP628 CD Player
H&B CA-8050BT CD Player Logo
63 people viewed this question
Top H&B Car Audio & Video Experts
xxxxxx xxx
Are you a H&B Car Audio and Video Expert? Answer questions, earn points and help others
