Question about Kenmore Elite HE4 Electric Dryer
Need help finding door latch assembly part
Model: 110.45996400
Thanks
  • 5,911 Answers
Go to searspartsdirect.com and type your model number in the “Search by Model Number” block. The part can be located under the “Door and Latch Parts heading as item number 7 (part number 8181700). If you need step-by-step instructions on how to replace, just follow the link below:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you do not wish to purchase on line, take the part number provided to any appliance parts retailer in your area. I hope this helps you. Please post back if you need further assistance.
Posted on May 19, 2008
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: The latch assembly in the door broke and fell
Try this site
http://www.partselect.com/
or this site, for your part.
http://www.appliancepartspros.com/index.aspx
Good Luck,
I hope this helps
Posted on Oct 15, 2009
Testimonial: "Thanks. I think I found a part that can work..."
How do I remove the passenger door latch assembly?
Buy a manual like haynes or chiltons for your model or go online and see if you can find one on download. This is a bit of a fiddly job that requires some experience so find a neighbour who know whats what or home mechanic type but a manual would be a good long term buy for any future faults.
May 02, 2015 | 1996 Ford Thunderbird LX
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Model KUDS01IJBL0 will not start. Keeps reverting back to 2 minute drain when Cancel button is pressed. After the 2 minute drain, I press "Normal" button, or any of the other start buttons with...
If your dishwasher won't start the problem could be the door latch or door latch switches. The door latch assembly is used to hold the door closed during the cycle to prevent water from leaking and it also incorporates the door latch switches that supply power to the dishwasher controls. If the door cannot close properly to activate the door latch switches or if the switches are defective then the dishwasher controls will not receive power and the dishwasher will not start. Inspect the latch assembly including the switches.
The door latch assembly is typically located at the top of the door, behind the inner door panel. To gain access you will have to remove the screws that secure the inner door panel and then separate the inner and outer door. The door latch assembly will normally have two switches that are wired in series as a safety feature. Verify that the door catch will activate the switches by manually inserting the catch into the latch assembly. If both switches are being mechanically activated then you should next check the switches for continuity with a multi-meter. Remove power from the appliance before attempting this repair.
You can learn more on our recent post about the dishwasher 5 simple mistakes you make while using dishwasher Kitchenutilitypro
Sep 26, 2017 | KitchenAid Dishwashers
The dishwasher door snaps open, stopping cycle. The friction catch often requires multiple presses to hold closed sufficient to allow the cycle to begin. I would like to know what adjustments are required...
Welcome to FixYa.
I suspect based on your description...it is the door strike that is likely fatigued as is common with these machines, thus allowing the door to "pop" open. The latch doesn't hold it closed, it just activates the switches, the strike is designed to hold it closed.
It is part # 8574157 and will look like the image here...
You do not need to remove the control panel to access the strike for the door latch assembly. It is done simply by pulling up (may need a flat screwdriver or the like) on the latch and forward. The new one also simply clips in place.
**make sure to turn off the breaker/power before servicing the unit...safety first**
Let me know if you need any further assistance and I will try to help in any manner I can. Good luck,
Regards,
Macmarkus :)
Jun 08, 2011 | KitchenAid Dishwashers
Kitchenaid dishwasher KUDP02CRBS3 door latch keeps releasing
Hi!
You can do it yourself if you remeber all safety precautions and have the right tools. These pictures will help you---
Door latch assembly (part #10)
Door latch view
Dishwasher Door
You can buy the door latch from this link---
Door latch assembly
Please ask for further assistance and Do rate the solution as "FixYa" if you found it useful.
Thanks
Rylee
Mar 17, 2009 | KitchenAid 24 in. KUDG25SH Built-in...
Getting F dl error on Whirlpool Duet HT
"Fdl" is normally cause by a failure of the door latch assembly. However, before assuming you have a bad door latch, the manufacturer recommends you unplug the washer for 30 minutes to reset the computer. If the error still persists, here's a link that provides all the instructions necessary to replace the latch:
Searspartsdirect.com carries the replacment latch you need. Just type in your complete model number and look under the listings on the next page. There should be a link for door latch parts. Repairclinic.com also carries to part, sometimes for less. I hope this helps you. If you need further assistance, please let me know.
Aug 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Door latch is broken
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
BUT - please note that we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Oct 20, 2007 | GE Advantium SCA2001BSS Microwave Oven
Kenmore Elite HE4 Electric Dryer Logo
123 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
