Question about RCA F27440 27" TV
My tv suxxx
My tv is a 46" Sony. It is probably 6 years old. Recently the picture only comes on for a minute then the screen goes black. The sound works perfectly any ideas?
    President:
  • 2,992 Answers
I'm assuming this is a projection set given the size. Sony TV's have circuits to monitor picture tube operation and cut off video when something isn't within limits. It's very likely your set has one or more bad tubes (there are 3, for red, green and blue), troubles on the circuit boards connecting to them, or problems with the set's control circuits. This set should be serviced by a professional if you want to keep it.
Posted on Jul 01, 2008
Samsung 46 DLP picture freezes and then....
common problem on samsung. bad DMD BOARD. these are modules located on light-engine. there very proud of this little jewel. usually parts cost 400-500.00 dollars for the shop. after mark-up & labor don't be shocked at 600.00-700.00 repair bill. this is of coarse for dmd replacement. 85-90%. if logic board, est. 400-500.00 repair. mch
Mar 09, 2009 | Samsung DLP HL-P5663W 56" TV
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
Screen Goes Black
it sounds like your "lamp" is going out look for a hidden compartment.. or in your owners manual to see where its located its an easy fix and costs much less than a new tv
Oct 16, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
Picture is there briefly then goes black with sleep timer blinking
your tv had a cold solder,so try to resolder the vertical ic. or vertical section as well.
Sep 05, 2008 | Sony KV-35S42 35" TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
RCA F27440 27" TV Logo
35 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
