Question about Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W wont come on
The lights showed lamp replacement, I installed a new lamp but set wouldn't come on. I re-set the lamp and messed with the switch in the back and still nothing, just a beeping noise. I took it to a TV repairman, he tells me the color wheel is fine but I need to replace the flywheel $360. What is that, and am I getting ripped off?
Thanks Same as new lamp not picture. Have yet to take to a repair man would like to know the answer to what is a fly wheel, real or ripoff
  • 472 Answers
He may have meant "fly back" in this case referring to the ballast transformer for the lamp.
The ballast can be obtained from HERE for far less then he is charging. It is all but a swap out part. The only thing is the site has a wait time of almost 70 days though it will give you an idea of what price to expect for the part, then add labour onto that.
Posted on May 18, 2008
After installing new lamp with new housing it shows Error message
I don't know whether you have taken all the precautions before replacing the lamp. Before and after the lamp replacement, lamp time has to be set. Otherwise, the projector will show error message when you switch it ON after the lamp replacement. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Nov 30, 2014 | Office Equipment & Supplies
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
Installed a dimmer switch to a light. Put power back on and the light came on. Wouldn't dim however and when I turned it off it would not come back on. fuse is OK
Is the dimmer rating higher than the load? Are you trying to dim fluorescent lamps? A flourescent requires special dimmer switch.
If you over loaded or mis-wired a transistor or wire wound dimmer, you may have damaged it.
Is this a three way light circuit?
May 30, 2011 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
LAMP light blinking after replacement.
Lamp Fan or Ballast board,problem could lead back to Dmd Module Encompass Parts Distubtion has what you need for this Set 1-800-638-3328
Feb 24, 2010 | Samsung HL-P6163W 61" TV
Indicator showing LAMP. Does this indicate the lamp needs replacing?
Yes. The lamp is timed and the replacement indicator signals when the lamp is near end of life. If the lamp fails catastrophically it makes a mess... best to replace before that happens.
Jan 03, 2010 | Dell 3400MP Multimedia Projector
Projector's lamp won't light up.
Change thermostat and service it.Then solve your problem.
Dec 12, 2009 | BenQ PB8220 Multimedia Projector
Ballast error status - lamp voltage too high
You need to replace the balast as the voltages are buringing the bulb out and this is caused by a balast that is bad. The baslast is what the bulb connects to this has a sensor on it that relays voltages and heat back to the main control unit.
Oct 23, 2009 | BenQ SP820 Projector
Tv only 2 years old
I don't know your set in particular, therefore I will be generic.
On some projection sets, there is an hours counter that is manualy resetable. Make sure that it is reset. If you can have a readout of the amount of hours used on the lamp this will tell you if this needs to be reset.
Normaly, when the set reacts as per your description, there is a cooling problem, or a fault in the power supply.
Also with your model of set, check to see if there are any safety switches that work with the cover or door for the lamp access. With the safety switch option, if the uPC thinks that the lamp is not properly enclosed or installed it will not allow for proper startup.
Jerry G.
Apr 13, 2008 | Mitsubishi WD62628 62" Projection HDTV
Unit does not have a flywheel. Assemblies include lamp, ballast, color wheel, dmd board, light tunnel, main and/or digital and analog pcb as well as power supply. These are all the assemblies in DLPs. The problem you described is usually lamp or ballast, but can also be from dmd or other circuit boards. Make sure lamp cover door safety switch is secure and fully engaged after replacing lamp or removing rear cover. I admit these sets are not cheap to repair. Good luck, Russmann.
Mar 27, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Lamp light blinks after lamp replacement
I have the service manual and it shows two door switches Dr 1 is in the back of the set on rt bottom below the temp. sensor. Dr 2 is at the front panel where you open it to replace the lamp. If one of these switches are open, it would show a lamp problem. If you have a Muiltimeter and can get to the switches see if one of them is open. Hope this is helpful.
Nov 09, 2007 | Hitachi 50V715 50" Rear Projection...
Samsung HLN617W 61" Rear Projection HDTV Logo
47 people viewed this question
Jerry Greenberg
Jerry Greenberg
