Question about Yamaha RX-V661 Receiver
NO sound on Zone 2
I connected 2 outdoor speakers and I can not get sound. using the interal amplifier.
I m guessing it is a yamaha receiver? if it is like my yamaha.
u hit
menu
manual setup
enter
basic menu
speaker set
extra set comes up on mine first...here u can choose none...precence and zone 2 speaker
if u click the right u only see zone b and precence and off.
click the left a-e/cat button to see zone 2.
they made it so confusing and the manual doesnt help.
other than that click on front panel zone 2 on and on front u have the what u want to play in zone 2 most are only able to play tuner in the second zone.
hope it helps u
jeff
Posted on Aug 09, 2008
  • 979 Answers
Did you use the same terminals or two different ones to make the connections?
Posted on Jun 20, 2008
Is there anyway to get an amplified signal to my zone two speakers without an additional amplifier? Should I be using the Speaker "B" outputs?
Check your speaker setup menu to make sure that zone 2 is enabled. Also, a lot of receivers only allow analog inputs to be used for zone 2, so if you are using something like hdmi, or optical than this might be the problem.
Jul 27, 2016 | NAD T754 Receiver
Zone 2 Amplifier Need
Reread the detailed answer provided in response to your earlier post on this issue
Jun 10, 2013 | Pioneer VSX1020K Receiver
Pioneer VSX 1020K - Zone 2 Setup
I referred to a similar zone 2 arrangement for a Yamaha receiver. It shows a separate amplifier and notes that only analog signals are sent to zone 2. The analog output from a source must be connected to the analog input on your Pioneer unit for zone 2 to work. Your outdoor music environment will be limited to left and right front speakers and...alas...no surround
Jun 03, 2013 | Pioneer VSX1020K Receiver
I recently moved and just got my outdoor speakers hooked up. When I turn on Zone 2, I get sound from my Ipod, but when I set Zone 2 to have music play from my satellite box, I get nothing. The music will...
If your satellite box is connected using a digital cable to the 601 receiver you won't get any sound through zone 2.Zone 2 can process only analogue sound ( inputs ).
Jul 06, 2011 | Onkyo TX-SR601 Receiver
We wired our new home to have outdoor speakers and also speakers to our pool room. Before putting the receiver back into place after wiring the back, we quickly touched a speaker's wires to the wires...
It's not really clear if all of this is Zone 2 or not, or if you intend a second program to play in Zone 2.
If your Zone 2 is to a powered amplifier and its speakers the Zone 2 output would be FIXED (not variable from the host TX-SR705), that is, at a level that the receiving amplifier would control.
Page 99 deals with it.
Having just passive speakers in Zone 2 requires you to set Zone 2 to "ACT(ive)".
Mar 27, 2011 | Onkyo TX-SR705 Receiver
Hi I want to add 2 extra speakers (for outdoors) to my Pioneer VSX-519V and see in the manual that I require a separate amplifier. Why is that necessary & if so can you recommend one please ? Thank...
Technically, you dont need an additional amplifier to run another set of speakers. This amplifier has a second zone output option. What you need to do is connect your outdoor speakers to the second zone on the reciever, than you can turn it on and select the desired source from your remote.
Jan 03, 2011 | Pioneer Audio Players & Recorders
Outdoor speakers on Zone 2
Hello Fixya customer,
Thank you for your question.
Please verify that Zone II power is "Acitvated" from the Hardware menu.
Thank you for using Fixya, an let me know if you have any additional questions.
May 01, 2010 | Onkyo TX-SR605 Receiver
Zone 2 problem for AVR 3808
It doesnt down convert to zone 2 via hdmi.... must use analog audio or something else.
Jul 14, 2008 | Denon AVR 3808Ci Receiver
No zone 2 sound coming from yamaha amp rx-v861
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Jun 29, 2008 | Yamaha RX-V995 Receiver
Zone 2 connections
go into your amp settings menu then to speaker settings,set zone 2 on and main on, turn up the volume for zone 2 about half way then connect phono cables from zone 2 pre out to a input on the external amp (eg cd input )
never use the phono input this is for turntables,connect this amp to your speaker switch/selector then to speakers.
hope this helps
cable guy.
Jun 04, 2008 | Yamaha RX-V2500 Receiver
Yamaha RX-V661 Receiver Logo
540 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
